Go to Post Andy Baker can legally touch the Red and Blue Carpet simultaneously. - Taylor [more]
  #31   Spotlight this post!
Unread 16-09-2004, 11:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Best frame building material
Originally Posted by dddriveman
80/20 is the best material hands down. It is so light and easy to work with that you can have a working frame in as little as three hours if not less.
80/20 is only light if you weld it.
When you add in all the connectors, it gets very heavy.
We have used 10/10 since 2003. It was nice since we could just slide stuff around to get it out of the way to access the innards of the robot, or realize that we made a design error and slide a few bolts to correct it. In 2003 we used all the connectors, which added up to be a pretty hefty penny. We didn;t have an issue with weight, but then again, our robot only weighed 90 lbs after we ripped our entirely ineffective stacker off it
In 2004, we had a lot of 10/10 left over, and had access to welding equipment, so we welded the 10/10. The frame was extremely light, and still retained most of the modularity you get with 80/20.
Some of the problems with extrusion include the fasteners slipping. This was particularly evident on both robots in that the wheels would continually slip from their intended mounting points. It's easily fixed, but a pain in the $@#$@#$@#. You really have to be sure to check all the time that your connectors are securely fastened. By the time we got to Cal Games in 03', the robot was literally coming apart because everything was so loose.
Before 2003 we had used 1.5" aluminum angle, and in 2002, we used 1.5" steel angle, which left us with a frame that was probably in excess of 40-50 lbs (Way too much strength, even for a game that was nonstop action)
Cory
2001-2004: Team 100
2006-Present: Team 254
  #32   Spotlight this post!
Unread 16-09-2004, 12:04
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
We have used big aluminum plates separated by spacers since 2001. If you carefully place the plates and don't get carried away with making them too big, this is definitely a lightweight approach. If you are less careful about where you place plates, or if you make them huge for no good reason, it gets heavier.
One nice thing about this approach is that its easy to make multiple parts at once on a mill - once you decide where your holes are, you can make enough for one or two robots in one setup. So it can be a time- and money-saver if you are doing your own milling.
Another nice thing is that the plates serve as great mounting surfaces for things like the drive system - you don't need any extra brackets so this contributes to the weight savings. It is a natural for custom geartrains and multi-motor drives.
Its easy to mill your team number into the side of the bot too! )
We have used a number of methods to extend structure between the plates: angle aluminum, flanged steel tubing, or other plate structures. My favorite is chrome-moly steel tubing (0.035" wall for "normal" locations, 0.058" wall for those exposed bumpers) with little three bolt flanges welded on the ends. Strong stuff and not too heavy, easy to mount a controller board with just a few tie wraps.
Ken
  #33   Spotlight this post!
Unread 16-09-2004, 23:00
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
we used (correct me if i'm wrong) 80/20 1" steel box tubing this year to build our frame. for those of you that were in the practice area behind the pits at SLR, you know just how strong the frame was. our robot ran full speed into a solid concrete post during an autonomous mode practice run and came out unscathed, we did more damage to the post!
and i must admit, making modifications during the build season was a snap, we just used either a hand saw or a plasma cutter to hack off the parts that we didn't need
  #34   Spotlight this post!
Unread 16-09-2004, 23:11
Cory's Avatar
AKA: Cory McBride
Minor correction, 80/20 is aluminum
It can take some big hits as long as you make sure you've got everything braced up well. At first in 2003 we had some doubts as to whether 1"x1" would be strong enough, but it turned out it's plenty strong, and much lighter than 1"x2", which is serious overkill.
Cory
2001-2004: Team 100
  #35   Spotlight this post!
Unread 16-09-2004, 23:17
Umm Errr...
Cory
Thats a pretty good idea.. Did you have to sand off the anodization first?
1139 Alumni
  #36   Spotlight this post!
Unread 16-09-2004, 23:25
Cory's Avatar
AKA: Cory McBride
I'm not sure, really. We didn't weld it, some welder at the place where one of our engineers works did it. I'd imagine that they did though.
Cory
2001-2004: Team 100
  #37   Spotlight this post!
Unread 17-09-2004, 04:43
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Cory
That happened to us our first year of using extrusion (2003).. after two regionals our robot was in pretty good shape, but after going through playoffs at Nationals- and keep in mind we took Galileo- our entire frame was warped. The extrusion slipped so much, Daisy 2 is more dented than the average metal canoe. Extrusion was awesome, but the thing that blows my mind is: we had a simple drive system and simple one-motor arm, but we still maxed out at 130 pounds. It's too darn heavy.
We did that this year, and it should've helped except for the extreme weight loss we had to undertake. lost 15 pounds at chesapeake, our frame became so weak and vulnerable before we even set foot on the field. To make things worse we had a faulty control board for our first 5 or so rounds so our robot (dual speed worm gear drive) literally bent its own frame before we could even really compete. Miss Daisy III is crooked now, but what can I say, last year's Miss Daisy only had a T on, and the original Daisy was topless.
  #38   Spotlight this post!
Unread 17-09-2004, 19:56
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
There are a number of sources of reinforced nylon connectors that insert into the ends of the tubing and lock it together. [/quote]
What are some of the sources? Which ones have you found to be the strongest?
  #39   Spotlight this post!
Unread 17-09-2004, 21:31
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Originally Posted by superbeano2004
I was curious on what is the best material for building a frame for a robot. Last year, we used 1" aluminum tubing and it did well but it was difficult to weld and it was not as strong. I see other teams using extrusion tubing and I was also curious on why extrusion so good. Thanks for your help!
1251 (my team) used extruded aluminum becuase it is stronger then that alumnium tubing your team used, however is it much heavier. so a good word of advice if you want to be light don't use extruded use the alumnium tubing. Extruded is good if your goin for robustness. The decision all depends on your design. Hope that helped.
Drew,
1251 THE TECH TIGERS
TECHNOLOGY FOR THE 21st CENTURY
  #40   Spotlight this post!
Unread 17-09-2004, 22:32
RBrandy RBrandy is offline
AKA: Ryan
#0093 (NEW Apple Corps)
RBrandy is a jewel in the roughRBrandy is a jewel in the roughRBrandy is a jewel in the rough
Send a message via AIM to RBrandy
Vould you please elaborate on this a little bit? first off is does FRP come shaped like a panel? Or rods? tubes? what? I'm a little confused. It sounds to me liek you are saying it is a panel and you put in in the T-slot of unistrut?
First, let me answer this. We got square tubes. I believe it comes in a whole array of shapes and sizes. We took the unistrut, machined it down to a size that would nest tightly, but not too tightly, in the FRP. Then, we taped the hole, and screwed it in at a 90 degree angle to the instruct.
This is not frame related in the aspect you are asking about. Team 93, in addition to using the fiber glass (FRP), we also used a large 1/4 in. plate for mounting things, instead of using more pieces of 80/20. We used it to mount gear boxes, our battery, our electronics box, our programming, air compressor, etc. To make this plate strong we had one of our engineers brothers laser cut, then bend out 'ribs', if you will, to make sure it would not flex in any critical part. This part helped the robot meet the weight requirement and still stay robust.
I'm sure myself or Sean Schuff could conjure up some pictures of this plate so you can understand what I'm rambling about.
Team 93 Alumini
  #41   Spotlight this post!
Unread 17-09-2004, 22:33
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
This year we plan to use the engineering teacher's head, it has got to be the hardest material known to man.
-Rod-
Team 662
Colorado Springs, CO
  #42   Spotlight this post!
Unread 18-09-2004, 00:57
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
Like Cyberblue, we used extrusion in the past (except for the "pre-me" robots - Rowdy 1 [2000] and Rowdy 2 [2001]). This summer, though, we replaced the frame with a welded box (1 in by 1 in or so) and it worked perfectly. It was 2 lbs lighter and we had weight to put on a pump (essential to the arm). Even though we didn't do great at IRI (because our arm broke in two places during the practice match - took 2 hours to fix, and the whole energy left in a battery issue), the frame was definitely a plus, and welded frames are what separate the men from the boys.
An example: Teams 66 and 279, the awesome teams we allied with at nats. Though 279 did use some extrusion in their arm, both 66 and 279 had welded frames (as far as I could see). They had very few limitations, except when the opposing robot would knock it over by entangling with the arm.
There are many more examples of this. Good one: WildStang this year, Beatty 71, and Las Guerrillas (469).
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
  #43   Spotlight this post!
Unread 18-09-2004, 01:03
Cory's Avatar
AKA: Cory McBride
You don't even want me to list all the teams that have had great success with non welded frames.
2001-2004: Team 100
  #44   Spotlight this post!
Unread 18-09-2004, 01:05
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Umm. No. Fixing a welded frame after a breakage in the non-welded part at a regional where you really have no time for welding is what seperates them.
Welding = Bad.
I would rather take apart extrusion based frames and redo all the screws and fasteners than re-weld a part many times.
Anything that needs special tools and/or skills to maintain especially at a FIRST competition should be kept to a minimum, and welding is one of those special skills.
  #45   Spotlight this post!
Unread 18-09-2004, 01:14
REVving up for a new season
FRC #2848 (All-sparks)
i don;t know about you all but i bring my mig welder to all the regionals i go to ...infact i do
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Rendering Tips Tyler Olds 3D Animation and Competition 27 16-10-2003 01:32
Building material archiver 2000 1 24-06-2002 00:10
frame material survey punarhero Technical Discussion 12 21-02-2002 06:47
