Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 18-05-2004, 15:37
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
excel-inventor
This may just be way abstract, but can you reference dimensions from a part, off of an excel spreadsheet? This way one could make all the dimensions of an assembly change with each other, in effect making the assembly ajust completely if you change one thing! This would be way cool, but it sounds impossible to me, any help?
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 18-05-2004, 16:10
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: excel-inventor
(This is using Inventor 6)
I believe you can do this by using "Parameters". I haven't had any experience with parameters in Inventor, but if you dimension a sketch and go under Tools->Parameters It will come up w/ a display like this.
From here I noticed that if you click the "Link" button you can open an Excel file/sheet.
Maybe you've already figured this out, but I can't really tell from your post. If you're looking for help with what to do with the Excel file I can't really help.
Purdue Alumni
Cummins, Inc.
Unread 18-05-2004, 16:15
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Re: excel-inventor
Yes!
It is totally possible. I used this for school and on some projects it makes life a lot easier, I'll try and post an example tommorow.
I set up a sheet that Inventor sees as the first sheet in a workbook. I believe it only views the first sheet in a workbook when you use the Link button on the parameters page. The columns in this first sheet include (at least) variable name, value, and unit type. To do the actual calcuation I used other sheets in the workbook and then simply made the cells on the first "Inventor" sheet equal to the proper values.
<edit>
Thanks for the screenshot Clark, I didn't realize you'd posted. After you link the spreadsheet to Inventor you then type the "variable name" which you place in each row of the spreadsheet in the equation field on the parameters dialog box. I think that all of this is explained more clearly in the Inventor help.
Anyway, I'll try to post the spreadsheet tommorow...
Unread 18-05-2004, 17:35
Techincal assist
AKA: Brian Clegg
Re: excel-inventor
Awesome!!!!! Can't thank you guys enough! I can't wait to try this out at school soon! Thanks again!!
Unread 19-05-2004, 12:07
Greg McCoy's Avatar
boiler up!
Re: excel-inventor
Here's what I did...The Word document explains the assignment, and ought to explain why I used the Excel spreadsheet like I did.
Good Luck!
Unread 19-05-2004, 16:00
Techincal assist
AKA: Brian Clegg
Re: excel-inventor
thanks, I just have one problem, one I can't open your excel file (weird), and two, when I link the spreadsheet to the model (link or embed), it does nothing, other than appear under third party. Thanks for all your help, any new advice for this new problem?
Unread 19-05-2004, 16:54
Greg McCoy's Avatar
boiler up!
Re: excel-inventor
Sorry, I'm not sure why it's not opening correctly...try right-clicking and hitting "Save Target As" in Internet Explorer or something similar in another browser.
If you can get that open, you'll see that for each dimension I made a parameter name. For each dimension I believe that you have to put the proper parameter name from the Excel spreadsheet into the Equation column.
<edit>
I believe that you can't use the same names in the parameter columns in both Inventor and Excel at the same time, either. You have to put the Excel parameter name in the Inventor equation box. Phew...
Hope this helps...
Unread 07-06-2004, 15:18
R2K2D2 R2K2D2 is offline
AKA: Raj
R2K2D2 has a spectacular aura aboutR2K2D2 has a spectacular aura about
Send a message via AIM to R2K2D2
Re: excel-inventor
Yes you most definitely can use Excel in tandem with Autodesk Inventor. It seems like people so far have given you some great info about how to do this. Just as an FYI, this is how those infamous i-parts are done for bushings, bearings etc. Good luck and have fun!
Unread 07-06-2004, 19:23
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC &amp;amp; FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Red face Re: excel-inventor
If I might suggest, it is possible to have dimensions for a part be calculated upon a single base dimension all within Inventor. The spreadsheet idea is an excellent way and of which I was not aware. If you take notice in the nice screen capture in the previous post the dimension can be a numerical value or an equation. Substitute a formula using dimension variables and you achieve your stated purpose. Change the value of the base dimension and the entire set updates...
for example
d1 = d0/5
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 08-06-2004, 12:42
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: excel-inventor
I've found the embedded spreadsheet in iParts a key element in automating the creation of a bill of materials for my designs. By adding the Project Part Number and Description to iPart tables, I've created a hardware library with real vendor catalog part numbers and meaningful descriptions. Then, when I use these parts in an assembly, and create a bill of materials in the assembly drawing, it is automatically populated with the information I need to create purchase orders. No more trying to figure out what size & catalog number a "HexNut.ipt" is.
I've attached an example:
Pete Kieselbach
Unread 17-09-2004, 10:37
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Re: excel-inventor
In referance to the spread sheet being used in inventor. This is how cmoplex animations are being created. making multiple constraints occur at the same time and even haveing them start and stop......and then start again is made thanks to the spread sheets and through calc mathematics. If you would like a small view of what I'm talking about see www.cybersonics.org and look under inventor. See the animations and the one where the robot is at a 45 degree angle. you will see a robot drive, stop, turn, and then drive off screen to the right. This is only the beginning of what we have been able to do via complicated animation.
Unread 18-09-2004, 11:14
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Re: excel-inventor
If you need help doing what you want to try this website
http://www.sdotson.com/
he has a lot of great inventor tutorials he even has one on using spreadsheets to create parts. If you need iparts go to this site
www.cbliss.com
he has a ton of parts free for downloading. Good luck.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 18-09-2004, 12:02
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
Re: excel-inventor
The tutorials section of Inventor (at least on 7) will show you how to link Excel and Inventor, it's proves quite nifty.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
12 in. Wheel in Inventor 7 petek Inventor 1 17-01-2004 17:53
student inventor matt111 Inventor 7 13-01-2004 17:22
Users Guide To Inventor R2K2D2 Inventor 5 11-01-2004 14:09
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
