Go to Post Sometimes it's not about being fair. Some people are just very good at what they do. - Koko Ed [more]
  #46   Spotlight this post!
Unread 18-09-2004, 21:12
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Best frame building material
A good frame material I've heard of is carbon fiber board. You know.. the stuff motherboards are made out of. I'm guessing that if you make a basic chassis out of steel angle irons, and bolt on sheets of carbon fiber, it'll take a lot more damage than if you have polycarb side panels.
A related question:
I've seen how they make some airplanes, they get a big mold and use a special machine to lay carbon fiber all over it, making a shell. I've also heard they use this method for race cars. Of course I doubt many FIRST teams have access to NASCAR shops, but does anyone know how carbon fiber laying works? It would be cool to see a molded carbon fiber frame some day.
  #47   Spotlight this post!
Unread 18-09-2004, 21:47
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
Team 598 used a carbon fiber shell with Kevlar for support. That is really smart because both materials are very strong and very light. We use 60601 T6 aluminum but thats only becuase we do a lot of welding onto the frame and its the best application we have found. Just the right strenght and its light enough.
  #48   Spotlight this post!
Unread 20-09-2004, 11:18
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
Originally Posted by Greg Needel
FRP = fiber-reinforced polymer...essentially it is aluminum that has fiberglass or some other composite in the material which gives it the characteristics of both metal and fiber....I'm not sure but this seems like it could get expensive
Not quite. At least not in our case. FRP = fiberglass reinforced polyester.
As RBrandy pointed out, we used the square profile tubing for our robot and modified unistrut to provide connection points. There are certainly other ways to connect FRP components. We're looking at corner/T plates for this coming season. In a few instances we used nylon bolts and nuts to hold non-critical components together. They fared VERY well and are extremely light. We all know how quickly hardware can add weight to our robots!
As for availability, we purchased our FRP through Ryerson, a national distributor. McMaster Carr also carries FRP and actually has a wide assortment of shapes including sheets, u-channels, angles, solid and hollow rods, and square tubing. Prices are reasonable with square tubing going for about $3.50/foot. Check it out at McMaster-Carr. It is drillable, machinable, paintable, and extremely easy to work with!
A picture of our application of FRP can be seen here.
Sorry for the delay in responding to all the inquiries and good luck!
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
  #49   Spotlight this post!
Unread 20-09-2004, 11:50
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
(In response to welding)
The problem with NOT welding is weight. What I would suggest a team do (if it has some money) is to weld spare parts that are likely to get broken. For example, an arm is easy to break, and so is the frame. Weld spares of those. Additionally do NOT weld the entire robot. Weld PARTS. Weld a bottom frame and separately weld the top frame, and bolt those together. 4-8 bolts = better than 40 - 80 bolts.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
  #50   Spotlight this post!
Unread 20-09-2004, 17:48
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
One thing about composites like carbon fiber and the like which is really important.Don't not breathe the dust from carbon fiber. It causes lung cancer. The splinters are nasty also. They dont become infected like wood splinters.
  #51   Spotlight this post!
Unread 20-09-2004, 18:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Fiberglass splinters are freakin evil. Between laying fiberglass insulation, and creating a fiberglass shell for The Sandhill Challenge racer we built in 2001, I've come to hate it.
2001-2004: Team 100
2006-Present: Team 254
  #52   Spotlight this post!
Unread 06-10-2004, 09:56
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
Word up for the Baltic Birch ply wood. Our team (195) has been using 9 ply for the last 4 years and its worked pretty well for us. What we usually do is build the box and paint it and then screw plates of 1/8 inch lexan around the outside as protection against dents, alot of times we will also reinforce the front and back with some 1/8 inch angle aluminum because in some extreme cases the frame has cracked on us. The aluminum angles seems to aliviate this. Our last bit of "armor" is 4 upright pieces of 3/16 inchangle aluminum at the corners to guard against spiliting. This has proven to be very structurally sound and also presents a good base for mounting things; blind nuts for important things, machine screws threaded into wood for relays, speed controls, etc.
P.S. Shameless plug for Gorilla Glue. Works awesome on our frame.
  #53   Spotlight this post!
Unread 24-04-2005, 20:05
rocketdawg3000's Avatar
rocketdawg3000 rocketdawg3000 is offline
rocketdawg
AKA: bakari
FRC #0845 (Cutting Edge)
Team Role: Animator
rocketdawg3000 is on a distinguished road
Send a message via AIM to rocketdawg3000 Send a message via MSN to rocketdawg3000 Send a message via Yahoo to rocketdawg3000
Our team used extruded 8020. It's really light and easy to work with
2005 UCF Regional finalist with 1251 and 1270
2005 UCF Regional GM Industrial Engineer & Design Award
2005 Palmetto Woodie Flowers Award
2005 Palmetto Regional Judges Award
  #54   Spotlight this post!
Unread 26-04-2005, 20:47
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
I will agree with the easy to use, it is an industrial erector set .
BUT as for light weight... 80-20 is heavy stuff. That is were the the compromise comes in for a lot of teams, go with it and its easiness and sacrifice on the scales or build other lighter more challenging implements.
edit/
I think I should add that I do realize this is a year old thread, but still relavent.
Mechanical Engineer
Digital Lumens
NU ME: 2011
  #55   Spotlight this post!
Unread 27-04-2005, 14:13
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
I wise engineer once told me two things
1. There is no Best material, there are Right Materials.
2. Use the right application for whatever your material is.
Ok so time for what i think of Chassis materials, from the extensive research i've done at competition I have found that combinations are the best way to go, making a frame all out of one material is inefficent. Also Extruded Aluminum is a proven FIRST chassis material.
  #56   Spotlight this post!
Unread 28-04-2005, 11:21
Mini-D67's Avatar
Mini-D67 Mini-D67 is offline
The 'Wheelman'
AKA: Justin Davis
FRC #0067 (The Heroes of Tomorrow - HOT)
Mini-D67 is a jewel in the roughMini-D67 is a jewel in the roughMini-D67 is a jewel in the rough
Originally Posted by David Hoff
I agree with most of what Pit Bull said about extrusion. It is very easy to work with and is very strong. However, it is very heavy. When teams have only 130 pounds to work with every pound counts.
Thats not entirely true...
Our entire frame was built out of extruded, given it was was only 1/16th" wall 1x1, it only weighed about 14lbs! Thats not very much for how much frame we had!
Go here and click on 2005 Build to see some naked pics of the bot!
67 - Yeah... everyone knows why...
^InfernoX14^
Team 67 - Great Lakes/Buckeye Regional Winners, West Michigan Regional Quater-Finalists, Newton Division Winners and NATIONAL CHAMPIONS.
NATIONAL CHAIRMANS AWARD WINNERS
My short list -> 66, 68, 274, 279, 302, 904, 330 and 503
  #57   Spotlight this post!
Unread 28-04-2005, 16:47
so that held up for you guys pretty good? I saw a couple teams use 1/8" on the outside and 1/16" on the inside and other supports. But it all matters on how you apply it.
  #58   Spotlight this post!
Unread 28-04-2005, 18:22
Captain Rich's Avatar
Captain Rich Captain Rich is offline
I am 245
FRC #0245
Captain Rich is a jewel in the roughCaptain Rich is a jewel in the roughCaptain Rich is a jewel in the rough
In the past few years, I believe that my team has gone over kill on frames. We used 2x4 extruded in an H shape, 80x20, and the kit frame this year. All of thoes were overkill and never took a single dent. So this summer we are going to try a few frames. What experience do you guys have with the strengh of 1.5" angle alluminium?
Richtopia Prevails Again!
http://richtopia.vzz.net www.adamsrobotics.com
  #59   Spotlight this post!
Unread 28-04-2005, 23:33
AKA: Dr. Brooks
no team (WRRF)
We used 1.5" aluminum angle for the front and back of our robot for the
past two years. Last year it was fine because "violent" robot interaction
occured up on the platform and there was no room to build any speed.
This year we got the front of our robot bashed in during the quarter finals.
I doubt we will be using 1/5" aluminum angle in this way again.
  #60   Spotlight this post!
Unread 29-04-2005, 08:43
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
[quote=cdr1122334455]I wise engineer once told me two things
QUOTE]
Very good - and true. Each application is unique.
862 has used plate aluminum, 80/20, welded aluminum tube, and "L" channel in various years. "L" channel (of various sizes) has worked the best for OUR team on the frame. But that's because we don't weld (for many reasons, even though we have MIG, TIG, and Arc welding equipment), we have a tendency to over tighten without spacer blocks (crushing box channel), and we don't use/have CNC Mills or Waterjet cutting (otherwise plate would be nice).
For us, material selection is based mostly on fabrication technique. Look around, see what other teams with similar resources use, and try it out over the summer.
Brian Graham
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Rendering Tips Tyler Olds 3D Animation and Competition 27 16-10-2003 01:32
Building material archiver 2000 1 24-06-2002 00:10
frame material survey punarhero Technical Discussion 12 21-02-2002 06:47
