Sterling Engine To be used to power spacecraft
I know Deano didnt invent the Sterling Engine but there is much talk about his use of it in his water purifier. Seems that nasa is using one to power a spacecraft check out the article here
http://www.newscientist.com/news/news.jsp?id=ns99996419 |
Re: Sterling Engine To be used to power spacecraft
when i worked at the JHU applied physics lab i was on this project for a while.and it was very interesting stuff...specifically what we were working on was changing the range of temp differential to find best efficiency within the conditions of space, for the application that they would be members through the wall of the space station. 1 side would be inside utilizing the inside temperature of the station while the other is outboard using the cold of space...i wasn't on the project very long but i have always had the suspicion that they would pop up in this application in the future.
Is the stirling engine really better than the current power systems? For deep space, it may have an application, but close to earth, there is a great amount of solar energy for ready use.
it all depends on the effeceny of the system. the best solar pannels are at most 30-40 percent effecent, so if you can get a system that works at a greater effency then it would be worth it, even though there is quite alot of solar energy...
personally if it was me i would just make a really long extention cord and drop it to the earth so someone could plug in..... ![]() |
| Gas powered engine horsepower equivalent to electrical motor horsepower? | Elgin Clock | Motors | 30 | 22-08-2004 20:44 |
| Operator Interface power ISSUE | kacz100 | Technical Discussion | 11 | 27-02-2004 13:46 |
| URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! | kmcclary | Electrical | 8 | 10-10-2002 10:56 |
| power of globe motor with gear box? | Ken Leung | Motors | 5 | 21-11-2001 13:43 |
| Max mechanical power of motors, how is it useful? | Ken Leung | Motors | 1 | 09-11-2001 14:15 |
