Go to Post Never underestimate people's ability to underestimate. - Ginger Power [more]
Unread 21-09-2004, 23:52
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Dynamic Input/Output Changing
Originally Posted by Paolo
Has anyone made a bi-direction bus using the I/Os on the Robot Controller? That is, has anybody dynamically changed I/Os from input to output using software control?
Yes, this is pretty common function. You might look into using a state-machine to keep track of what direction the pins should be in at any given time.
-Kevin
Kevin Watson
http://kevin.org
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Changing Fields? Steve W Championship Event 8 08-04-2003 19:37
Changing the Elim. Format... Joe Johnson General Forum 46 08-04-2003 12:27
Changing the face of the game.. archiver 2000 19 23-06-2002 22:10
changing my name Travis Covington CD Forum Support 1 09-10-2001 08:37
