Go to Post Inspiration is created by a vision and is reinforced with success. - rourke [more]
Unread 22-09-2004, 12:17
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: pic: 1305 Frame design with trannies
Originally Posted by Hunter
They are a completely new trannsmission That I designed. Although I was definetly heavily influenced by Baker's design. It is designed to have Brecoflex tracks in the gap between the The 2x4s and the outsice plates, So the driveshaft out of the Trannies is designed to turn the back drive pulley for the tracks. The trannies are 2 speed with approxiamte speeds (70% of free speed) at 3.4 ft/sec and 9.5 ft/sec. Kinda slow compared to other designs but This is designed like a bulldozer.
Great design looks good and rugged. One quick tip, If your gonna use a track like brecoflex, which has alot of grip add in a center idler wheel which is larger than your drive wheel. It will aid in turning your machine. We used brecoflex this past year and without the larger idler our machine couldn't turn. This thread might also help you:
http://www.chiefdelphi.com/forums/sh...ghlight=tracks
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 22-09-2004, 12:36
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Looks like a great drive unit! Nice and compact, too. One suggestion: install them so the motors on both sides are turning in the same direction. (DC motors are almost always optimized for higher efficiency in one direction) Generally speaking, you want your highest efficiency in the robot's forward direction. This will give you slightly better torque and will be easier to balance for driving in a straight line.
Pete Kieselbach
Unread 24-09-2004, 21:28
Robot Dude 0101's Avatar
Robot Dude 0101 Robot Dude 0101 is offline
Robot Dude 0101 is an unknown quantity at this point
That is a very nice design. Too bad you stole that other person's idea! J/K
I will soon begin work on a robot with 4 wheel drive using heavy duty gas engines. I don't know how to use any computer programs like you so mine wont be as advanced.
Unread 24-09-2004, 21:47
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
Thats Awsome! A gas powered robot. About the Computer programs though, they don't make a design good or bad, they really helped me figure out stuff with the trannsmissions but I already had the major details worked out before I put anything down in Inventor. You can make cool designs without a computer. 1305's 2004 robot was designed entirley on graph paper and on the fly and it turned out very well for us. Don't say that you can't make an advanced design just because you can't use CAD. 50 years ago CAD didn't exist and that didn't stop anyone.
Good luck with the gas robot, let me know how it turns out, I think that is really cool.
Unread 25-09-2004, 01:13
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Not for FIRST you won't! I know you're new to FIRST, so I'll point out that gas engines aren't allowed, and very likely will never be allowed as long as FIRST maintains its current format. Fuel storage and spillage are of major concern in the pit areas, and on the playing field.
Also, the emissions and heat from those engines would make working around them hazardous in a FIRST pit area.
If the robot's for something else...enjoy.
pic: My vote for the best design from the team spirit "drawn" in the stands. CD47-Bot Extra Discussion 4 07-09-2004 00:19
pic: Team 303 Winner of the GM Industrial Design Award CD47-Bot Extra Discussion 9 20-04-2004 19:57
pic: team 1305 - The Mammoth Ayu Robot Showcase 2 04-03-2004 23:33
pic: 1083's final design unleashed!!!! The MIKEBOT 2000 CD47-Bot Robot Showcase 8 20-02-2004 23:41
pic: Team 710 Frame CD47-Bot Extra Discussion 4 16-02-2004 19:01
