Go to Post Each team is different, your mileage may vary. What works for your team does NOT necessarily mean it will work for others. - Andrew Schreiber [more]
View Poll Results: What is your preferred gear pitch?
12 dp 0 0%
16 dp 2 6.25%
20 dp 20 62.50%
24 dp 4 12.50%
32 dp 4 12.50%
48 dp 0 0%
metric (or other) 2 6.25%
Voters: 32. You may not vote on this poll
Unread 24-09-2004, 17:55
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Gear pitch preference
Originally Posted by Andy Baker
For you drivetrain gearbox designers, hear is a question for you: what is your preferred gear pitch?
Just one preferred pitch? With these 3-motor monstrosities I design, and the fact that we (at 188) never figured out exactly how to replace the gears (nor really tried), gears of all types find their way into my designs.
Older Woburn gearboxes used mostly 20 pitch, 14.5° pressure angle gears from Boston, because they were easily available, machinable, reasonably durable, pretty cheap, and featured in the Small Parts catalogue (back in the day...).
And the current Woburn design still uses 4 of them. But I was introduced to SDP/SI's line of hardened steel gears last year--and they're pretty neat too (hard to machine without an EDM, though). If cost were no object, I'd like to make greater use of them. I used the 24 pitch, 20° pressure angle ones, but they also come in 32 pitch, if my memory serves me correctly.
I don't like metric gears, because PIC Design sells them....
Edit: To clarify, last year's Woburn gearboxes contained 0.7 M/20° PA, 32 P/20° PA, 24 P/20° PA and 20 P/14.5° PA gears.
gears Michael Leicht Inventor 12 16-09-2004 10:52
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Relationship between gear pitch and diameter seanwitte Technical Discussion 5 24-01-2004 04:14
gear pitch BoticsPUNK Motors 2 19-01-2003 16:53
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
