Go to Post Past success does not guarantee future results.... - Koko Ed [more]
Unread 24-09-2004, 14:35
Alaina's Avatar
Alaina Alaina is offline
J = Pf - Po
FRC #0814 (Megaforce Squadron)
Alaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to behold
Send a message via AIM to Alaina
Do we have to program our robot in C++?
Hi,
The new programmer on my team was wondering, can we switch back to visual basic or do we have to use c++?
"It's cool to be a geek!" -- Dave Lavery
"It's all about the math." -- Mark Leon
Unread 24-09-2004, 14:51
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Stupid question that should be easy to answer...
Let me start by giving you a bit of information. Prior to 2004, PBASIC (similar to Visual Basic) was used as the programming language. In 2004, and as far as I know, 2005, the chip will be programmed in C (someone who knows C++ knows C, but they are not the same).
If your programmer knows BASIC, C should not be a very large step. If he starts learning now (practicing with the 2004 equipment) he should be perfectly capable by 2005.
Team 1257
Unread 24-09-2004, 14:56
Well, the robots have never been programmed in either Visual Basic or C++.
In the past, the robots were programmed in PBASIC, which is a dialect of BASIC that only runs on Basic Stamp microprocessors, which were what controlled the robot until last year.
Last year, and presumably this year, the robots are programmed in C for a Microchip PIC processor.
Even if your programmer knew Visual Basic, PBASIC is quite a bit different. C++ and C are quite a bit closer, but there is still a huge difference between programming a full computer, and an embedded control system.
You should suggest that they register on chiefdelphi because I'm sure there will be many more questions.
Unread 24-09-2004, 17:21
Alaina's Avatar
J = Pf - Po
Okay, thanks guys. Sorry for being so oblivious. =P
Unread 24-09-2004, 17:23
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Do we have to program our robot in C++?
No problem. "Oblivious" people asking questions are what gives us an excuse to sit around on CD.
Unread 24-09-2004, 21:42
Robot Dude 0101's Avatar
Robot Dude 0101 Robot Dude 0101 is offline
Robot Dude 0101 is an unknown quantity at this point
Im new to this FIRST stuff and I was wondering why these robots have to use these processors? We could use more powerful processors like the HandyBoard, Motorolla processors, or K-Team processors. That would make everything more challenging.
Unread 24-09-2004, 22:20
Billfred's Avatar
Billfred Billfred is offline
That's the thing--some folks have enough fun (ahem) trying to program the robots as they are. Adding in more powerful/complex processors only makes it harder for us (and rookies, don't forget the rookies) to learn.
Now, if by that you meant being able to use any processor, then there's another issue--as it stands, FIRST teams use pretty common things (mainly since they're in the kit of parts). If 1000 different teams use 1000 different processors, then it's going to be very hard for a programmer to walk to the rookie team next door and offer help, since their setup may be completely foreign to him/her/it.
Unread 24-09-2004, 22:22
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Programming is, for many teams, one of the aspects of making their machine they find most difficult. In recent years, FIRST has worked hard to make building a robot easier, but at the same time providing the headroom for more experienced teams to innovate. The new control system provides a pretty good balance. I think Microchip PIC Processors are used a lot in industry, so this also may be part of their choice.
(Also, if I'm not mistaken, the PIC uses a Motorola processor...)
Unread 25-09-2004, 11:51
Even though it would be hard for teams to help each other, it would be an interesting idea to let teams use whatever processors they want. But this would only be useful if there was no $300 sensor limit. Since there is, I agree with you that the same processor is a good idea.
Unread 26-09-2004, 09:03
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
FIRST will publish the "Official Rules" at the kick-off. I am sure there will be restrictions, as in the past, regarding the controller, specifically the software. There is great effort at making all teams even in many respects as well as constraining the technical issues FIRST tech support will have to deal with.
In the past you were NOT allowed to modify the OI or RC in any way other than programming. In addition, usage of additional electronics is specifically controlled each year.
I am sure the controller will not operate on any other language other than "C".
Read the "Official Rules" when they are published by FIRST.
Ask here if you need additional information. The community of Chief Delphi will respond.
Mike Martus
Unread 26-09-2004, 11:23
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It should be possible to program the RC in a different language, like PIC assembler (because it's the job of the compiler to write a .hex file, which contains generic PIC instructions, rather than C code or some other language). However, there's absolutely no support for this, and it would be a miracle if someone got a re-coded version of the firmware to actually work with itself, much less the field controllers.
Unread 26-09-2004, 12:16
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
We should use Java....not! It will take forever for the virtual machine to load ("it's 45 seconds left and the robot is standing still") and for the navigation system, "Java.lang.Math is loading...." I guess C is a good alternative (even though I am terrible at C programming). Java has great uses as a dash program, though.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Unread 29-09-2004, 21:59
Dekker Avesque's Avatar
Dekker Avesque Dekker Avesque is offline
None #0173
Dekker Avesque is an unknown quantity at this point
Send a message via AIM to Dekker Avesque Send a message via MSN to Dekker Avesque Send a message via Yahoo to Dekker Avesque
You make it sound as if C++ is for programming on a PC and C is only for embedded control systems, when this is not the case. C and C++ were both originally for PC programming; C is merely the predecessor language to C++. C and C++ are nearly identical; C++ is C with object orientation. (C++ was originally described as "C++: Object Oriented C".)
I believe the C used in the Innovation FIRST chips that we run our robots with is a simplified version of the language, specifically suited for said chips.
Just making sure there is no confusion... C was not designed for operating robots, however a compiler was released for FIRST allows us to use the C language to operate robots.
Unread 02-10-2004, 22:03
Does anyone know of any good books that would teach you how to program C for robotics?
Unread 02-10-2004, 22:41
av11d's Avatar
av11d av11d is offline
College Bum
no team ((Team 75 Alum -- Capt 05 & 06))
av11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to beholdav11d is a splendid one to behold
Almost. C with an object-oriented extension is ObjectiveC. ObjC is what NeXTStep and Mac OS X use as the default programming language. C++ is rather a completely rewritten programming language that originates from C. I still like Java
Anyway, if you want specific information on using C with the standard FIRST controller, check out: http://www.innovationfirst.com/FIRST...umentation.htm
Best of Luck!
2003 Animator and FIRST newbie
2004 HP, Animator & Programmer
2005 Team Captain, Arm Operator & Animator
2006 Team Captain
2006 BOSTON ENGINEERING INSPIRATION WINNERS
2006 NJ ENGINEERING INSPIRATION WINNERS
2006 BOSTON AVA WINNERS
2005 DUEL ON THE DELAWARE CHAMPS w/ 222 & 1721
2005 BRUNSWICK ERUPTION IV CHAMPS w/ 358 & 369
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
2003 EDU robot Program nragod Programming 3 15-02-2004 22:35
Image Discuss: 810 - Minotaur: Coming to a regional near you. CD47-Bot Robot Showcase 47 25-02-2003 16:19
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
