Go to Post You are given a goal with some simple restrictions. That's it. No one really cares how you get it done, just the fact that you get it done. - Max Lobovsky [more]
Unread 25-09-2004, 11:31
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
HP Photography Commercials
Does anyone know how those crazy HP photography commercials were made (like the one with the guy singing and putting pictures down over his head and then bringing them back up)? They're driving me nuts trying to figure it out!
My thought is that he starts out with a blue screen-type card, and when it gets close enough to his face, they stop, switch the card to one that is just an edge, start filming at the exact same spot, and visa versa.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 25-09-2004, 14:17
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: HP Photography Commercials
I'm not sure what you're talking about.. but I don't think bluescreens are used too much anymore with the power of CGI and all that stuff. I could be wrong.. but I'd just guess it's some fancy computer work (as is everything )
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 25-09-2004, 15:44
Alex Pelan's Avatar
Alex Pelan Alex Pelan is offline
GO IRISH
FRC #0177 (Bobcat Robotics)
Alex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant futureAlex Pelan has a brilliant future
Send a message via AIM to Alex Pelan Send a message via Yahoo to Alex Pelan
The commercial is about this guy, who holds these picture frames up to his face at different angles and whatnot, and then, when he removes them from his face, the image that the frame was surrounding is in the frame. I, however, have no idea how it is done.
Team 177 - Bobcat Robotics (2004-2007)
University of Notre Dame Class of 2011
Unread 25-09-2004, 17:39
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I have not seen a write-up of the methods actually used by the HP commercial team (I've checked some of the trade press, but haven't found anything published yet), so I can't state categorically that I know the techniques that were used. But I have talked with several of my friends that are commercial animators, and we have figured out how we would do it if given the job. It actually is pretty straigt-forward:
1. Measure the distance from the camera to the actors, and the dimensions of the picture frames. Measure the intensity, color temperature, and position of the primary light sources. Save this info for later.
2. Film the commercial all the way through with full sets. The picture frames are just empty cardboard frames, painted white. No blue screen or stop action necessary.
3. Use CAD software to design a picture frame polygon, with the same exterior dimensions as the original picture frame, but no center hole (i.e. a solid polygon). Build a lighting model based on the information saved in Step 1.
4. In post editing, stop the each point where you want an "empty frame" to become a "frame with picture." Capture the coordinates of each corner of the picture frame in the image, and save the image within this polygon to a separate location.
5. Using the information saved in Step 1 and the captured coordinates of the frame corners, solve to determine the position and orientation of the frame polygon relative to the camera. You can do this manually, or there are several commercial software packages that will do this automatically for every frame once you identify the initial polygon (note: this is a fairly common technique - you can find lots of information on extracting geometry from images in any of several image processing texts; one good place to start is with this Tutorial on 3-D Modeling From Images).
6. Adjust the relative postion and orientation of the CAD frame model and virutal camera to be identical to the real scene. Texture map the image saved in Step 4 on to the CAD polygon. Render the texture mapped picture frame with a 100% alpha channel for the image background. Composite this back on to the original image from the filmed piece.
7. Repeat Steps 4-6 for each version of the picture frame in the piece, always using the same image captured in the first run-through of Step 4.
That should do it!
-dave
Unread 25-09-2004, 19:41
FiM Volunteer
Thank you for such a detailed answer Dave! That answered my question completely.
*Runs off to start an 'I am Dave Lavery' cult, er, group*
Unread 23-03-2006, 04:18
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Just saw another one of these recently. They are just about the neatest commercial on TV, IMHO.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 23-03-2006, 07:00
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
You know the sad thing is I understand what Dave said and it was pretty much what I was going to say, there never is any pictures there, they take a screen from the video where the photo would be and use it as a skin for the model and have it move with the frame.
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
MasterCard commercials Raven_Writer Chit-Chat 4 04-09-2004 18:24
Photography Barry Bonzack Chit-Chat 7 08-08-2004 02:41
Retro Reflection Vs. Flash Photography... Joe Johnson General Forum 13 23-02-2002 16:07
