| It's EASY to C why I PROfess my love to you! |
mplab iso
hello i was wondering if anyone could provide me with mplab iso. the copy i got from a team member seems to be a pbasic stamp editor which isnt going to help.
i would be really happy if someone could do this for me. |
Re: mplab iso
This is going in the same direction as this thread.
So to sum it up, it is illegal to do this for any purpose. MPLAB is also free at microchip.com I believe the website is. The only real purpose of the CD is to install CBOT (which is a compiler ment for the robot). Distributing the CBOT file(s) is illegal, since MicroChip requires you to pay for it on their site (which I believe FIRST already did when they gave it to us last year). My suggestion is to find the CD from the previous member(s) who have had the CD, and go that way. This way you won't be doing anything illegal. Last edited by Raven_Writer : 26-09-2004 at 09:01. Reason: I don't know my english |
Re: mplab iso
i cant get into contact to the only member of the team that i know has it. and i think theat the one that came with the kit is missing.
Re: mplab iso
Like Raven_Writer said, it is illegal for us to distribute it, especially without any way of verifying that you really should have it.
You do have a lot of options though. Talk to your mentors/teachers. They should be able to help you track it down much better then you can on your own. Use the demo version. MPLAB is a free download, and the C18 compiler has a 60-day trial version availible to download. 60 days from today is the end of november, with only a month or so until kickoff. If you plan it right, you could make full use of the demo, and not end up with much downtime. Buy it. As said above, MPLAB is free. The C18 compiler is $495 from microchip. Or, you can buy the C-BOT version from Innovation FIRST for $49.95. |
Re: mplab iso
To write code for the robot, you need two things:
*MPLAB *C18 compiler The full version of MPLAB is free and available from the microchip website. There is also a fully functional demo of C18 available. My advice would just be to use the demo until the start of the next season. I believe that the only limitation on the demo is a time limitation. When it expires, just download a new one. |
Re: mplab iso
Please note I'm not endorsing any actions, just giving more information on how to do something of this sort. |
#7
Re: mplab iso
well im gona use the demo untill the season starts.
when i installed mplab 6.60 it installed usb drivers. is mplab going to be teh program we have to use next year. ot/ edit. i just found a simulator mode in mplab. so i answerd my queston from a coupel weeks ago /ot Last edited by CmptrGk : 26-09-2004 at 12:12. |
#8
Re: mplab iso
Re: mplab iso
how would one compile the program from the command line?
#10
Re: mplab iso
Open up a command prompt, goto the directory the CBOT compiler is found at, type in the the filename (say, "compiler.exe"). it should get you a bunch of switches (commands) you can use. go by that. If you want to see what folders and files are in a directory, just type "dir" in the command prompt (w/o the quotes). I dunno if this was already stated, but you could also just buy the compiler even though it is a lot. Maybe they'll discout it for you if you can prove to them that you are a part of FIRST. |
#11
Re: mplab iso
im going to ask our engineer if he knows where mplab/cbot is. if we cant find it im gong to be stuck with the demo
#12
Re: mplab iso
Re: mplab iso
Re: mplab iso
Last year veteran teams did not get the EDU kit, but they did receive the EDU controller and the IDE/compiler CD. I assume veterans will not receive the Robovation kit this year either in keeping with your quoted reference, but there is still hope for a controller and the CD.
It would be an obvious cost-cutting measure to not send the Robovation controller to teams that received them last year if it's identical to the 2004 controller. It's a ray of hope for Dillon, but not as Joe implies, guaranteed. |
#15
Re: mplab iso
YAY my our engennire found our copy of the install files. so now i can continue on programming the robot.
| Development enviroments orther than MPLAB | wun | Programming | 36 | 29-04-2004 21:20 |
| MPLAB Variable Simulator? | Chris_Elston | Programming | 3 | 18-02-2004 12:08 |
| If you're having MPLAB problems, LOOK HERE. | Jeremy_Mc | Programming | 0 | 20-01-2004 18:06 |
| Im am having trouble with the MPLAB | hedgehogger | Programming | 7 | 19-01-2004 17:37 |
| using the MPLAB IDE MPLAB SIM simulator | WizardOfAz | Programming | 1 | 03-11-2003 01:24 |
