Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Go Back   Chief Delphi > Other > FIRST Lego League > Lego Mindstorm Discussion
Unread 29-09-2004, 06:50
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Using USB with Serial Tower
Are you saying you want to use a USB to serial converter to attach the serial tower to a USB port, or the USB tower to a serial port?
Unread 29-09-2004, 06:56
Mick Mick is offline
Mick is an unknown quantity at this point
I want to use a USB to serial converter to attach the serial tower to a USB port.
Only short progs will download because the tower is switching off. This is how I understand it from reading other posts.
I just cant find any mention of a solution to this that does allow the use of the USB to serial converter with the serial IR tower.
cheers
Mick
Unread 29-09-2004, 11:32
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
(For those of you who are seeing this thread off the portal you may not notice that this person is asking about the IR programming tower for the rcx of lego mindstorms or for FLL.)
-Michael Dessingue
ifi loader with no serial port Jared Stofflett Programming 4 23-02-2004 22:50
USB to Serial -- Working Device Found! Eko Programming 10 23-02-2004 12:56
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
USB to Serial Jack Programming 24 23-12-2002 14:21
