Go to Post Pro-tip: Friends don't let friends play defense! (in qualifications) - Mr. Lim [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 03-10-2004, 20:44
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Dual Displays, 2 Graphic chips
Okay so here is the deal- I want to use two displays (so I can have browser/text on one side and AIM and other stuff on the other). I have a crappy integrated graphics chip that came with my machine but I use a G-Force 3ti that is in my AGP slot... anyway I can get these two chips to work together so I can run 2 displays?
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 03-10-2004, 20:51
Rafi A Rafi A is offline
AKA: Rafghan
FRC #0935 (RaileRobotics)
Rafi A is on a distinguished road
Send a message via AIM to Rafi A Send a message via MSN to Rafi A Send a message via Yahoo to Rafi A
Re: Dual Displays, 2 Graphic chips
I'm pretty sure you can't. I'm 99% confident that the only way to do this would be with dual out video card
Unread 03-10-2004, 20:52
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I don't know what type of motherboard you have, but 99% of the time the onboard graphics are being routed through the same AGP controller that that the board's AGP slot is. Therefore, you can only use one at a time (unless your board has two AGP bus controllers).
Zan Hecht
Unread 03-10-2004, 20:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Can't you get a PCI video card and go duals that way?
Unread 04-10-2004, 00:43
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
That would probably work. I've never seen it done.. and never tried it.. since I've never had a built-in video card.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Enable both the onboard and your add-on card and see if your OS will see both separately. If you are using windows you can find this out with going through your control panel and see if it sees two display adapters.
-If this is the case then either through control panel or right click on your desktop, get to the display properties, then the Settings tab. you should then see similar to a scroll down button about mid way. click that and it'll show 2 motors. click on the second one, then at the bottom of that window there will be an empty check box saying extend my Windows desktop onto this monitor. once you click that click apply and you should see two different screens on your monitor. one with your normal desktop and the other seeming to be blank.
-If you do not see both adapters then you will need to get a board with 2 display out functions. once you get one of them (easily get one for $40 or so) follow the instructions above.
I have used this numerous times for copying FIRST video form soap's website to a VCR while still being able to see my normal desktop.
-Mike
Unread 04-10-2004, 01:32
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
the easiest and cheapest way to accomplish this is to buy a cheap pci video card. like it was said before plugging in your agp card disables your on-board video.
i run an ati video card and a simple and cheap nvidia pci card to run dual monitors in windows xp. unfortunately the on-board video feature is useless. good luck getting it up and running! its extra sweet when you get it working right......especially when you can run autocad on one monitor and inventor on another. perfect for robot design!
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 04-10-2004, 01:42
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Since all you want to do is have another window for AIM, a cheapo PCI card will probally be your cheapest and easiest solution. Another is to build a cheapo PC and just have a second computer. Another is a program I found that allows you to turn a second computer, like a laptop, into a second monitor via software. MaxiVista lets me use my laptop as a second monitor for monitoring AIM, but can't watch video on it because it runs over the network, and I've only a 10 card in the laptop, not to mention the ATT StarLAN switch they are running through. So I havn't really used it, because durring full screen games it shuts off the second screen, but it might work for you.
In my opinion, this is the best solution.
Wetzel
Unread 04-10-2004, 02:37
gobeavs's Avatar
gobeavs gobeavs is offline
linux advocate
AKA: Ross
None #1425 (Wilsonville Robotics)
gobeavs will become famous soon enoughgobeavs will become famous soon enough
Send a message via AIM to gobeavs
Another vote for a PCI card...if your GF3 doesn't have dual outs. It should, and nVIDIA's multimonitor support is pretty good, so I don't know why you just don't use that...
"Never in the face of human conflict has so much been owed by so many to so few."
- Winston Churchill on the RAF in WWII
CHIPS roboteer49 Motors 35 21-05-2004 12:18
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
