Go to Post They know how to make paperweights into other objects, like robot controllers. - Greg McKaskle [more]
Unread 04-10-2004, 13:34
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Dewalt Dual Motor
Unread 04-10-2004, 13:38
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: Dewalt Dual Motor
Couple of questions.
Any plans to publish the drawings?
Have you thought about or designed a way to use the CIM instead of FP?
Is the mount really strong enough? I can imagine some pretty high loads on the bolts (or is it welded or something like that?) attaching the angle aluminum to the shaft collar in a robot bouncing up and down.
Team 1257
Unread 04-10-2004, 15:51
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
So - what'd you end up using to final drive the gearbox? Did you pull the pinion off a DeWalt motor?
Unread 04-10-2004, 16:49
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I followed Dr Joe's method and used a planet from a second stage. I was tempted to run the 2nd stage missing a planet and still may try it after the initial testing is completed.
This design is flexible in that the transmission adapter has a lot of room to add countershafts. I could have designed it for the CIM and added more support between the transmission adapter and the motor plate. As it is the only parts that have 'real' drawings are these two main pieces. The clamp collar is held on with two 1/4-20 bolts but I think I like the OCCRA solutions and will replace the lower section with a block. I will test first 'cause you cannot learn unless you break something first!
BTW,I am looking for some suggestions on shifting mechanisms .
Andy Brockway
Team 716, The Who'sCTEKS
Unread 04-10-2004, 17:41
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by Andy Brockway
...BTW,I am looking for some suggestions on shifting mechanisms .
how is the XRP transmission shifted? is there a part that slides back and forth, or something that rotates, etc...
also, i recall Joe J. said that the XRP transmissions had 3 speeds to 'em. is this the case with your transmision?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 04-10-2004, 18:25
Fold em oval!
There is a piece that rotates (the black thing behind the torque limiter) to three positions. It rotates, but it's a relatively large diameter so its not too far from linear movement. It takes a good amount of force to move (very rough estimate - 5lbs) and has pretty strong detents on each position. Of course, this isn't really enough info to build anything off of...
I haven't taken one apart, Andy, so I can't really suggest how something larger than that little black knob can be fixed to that rotating shifter peice. Please keep us updated, though.
Team 1257
Unread 10-12-2004, 12:52
Engineer
An update on our testing this Fall.
The dual motor works well. We made a thicker spacer to hold the last ring gear as the torque out of the two motors was causing the clutch to trip when set to drill. The palstic gears on the Bosch are holding up well. We tore a brush out of one of the Boschs when the clamp collar was not full tightened and the unit spun. No problems with the motor mount to the gearbox. We also smoked a FP motor, it was an abused one from this past season and running at slow speed while turning the robot hastened its demise.
The Dewalt is flawless, it stays in gear and can take serious reversing loads. This was how we found out about the clutch slipping and requiring the thicker spacer.
I cannot wait to see what we get for motors this year!
Andy Brockway
Unread 10-12-2004, 19:51
artic_raven's Avatar
artic_raven artic_raven is offline
artic_raven is an unknown quantity at this point
Send a message via AIM to artic_raven
so is this the drill motor that we will be getting or are we going to get the ones from last year that almost fell apart?
Unread 10-12-2004, 20:31
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Nobody will officially know until kickoff. That drill motor is the same that we had in the 2004 kit. The transmission was bought separately from DeWalt. Numerous teams have been experimenting with the transmissions during the last year or so.
2001-2004: Team 100
2006-Present: Team 254
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
Team 45 Dual Motor Gear Switching Assembly WorkThoseBuns Motors 1 20-03-2002 19:27
[white paper] Dual Motor Gear Switching Assy Brandon Martus Motors 0 29-06-2001 12:56
