Go to Post What about "I h8 Autonomous Mode" (for the programmers who actually have to make the robots work)? - Tristan Lall [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 05-10-2004, 23:16
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
Potential MVRT(115) Design...
This is a first cut of the front page.
Sat down and tried to finish the design, did most of the front page and couldn't stand it anymore... so I'm going to ask for some feedback now...
I am mostly looking for constructive commentary such as "The main box with the photo of the robot is too pale a shade of purple/blue" or, "I like the visual identity created by the yellow header". Tell me specifically what you like or dislike, and I will be considerably happier.
But failing that, I'd love a pat on the back and a thumbs up... if only for the ego-stroking/motivational effects...
rawr
Unread 05-10-2004, 23:39
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Potential MVRT(115) Design...
The only thing I see that can use a change (and it is probably just because it is a screenshot smaller than my webpage viewing capabilities) is the size of the text on the top words (home,team, etc.)I would have to see the actual page fill up the woel screen to judge that..
Other than that it looks pretty cool.
Unread 06-10-2004, 16:49
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
I think it looks very good.
However (lol.. you knew that was coming), I don't like how there's a solid yellow box behind Monta Vista Robotics at the top. It doesn't fit with the striped yellow behind it. Either remove the box and just have the text on the striped yellow, or give it a design and blend it into the striped yellow.
Oh, and i'll ditto the suggestion to make the main links a smiggen larger
Aside from those two things though, I REALLY like it!!
Nice work,
jack
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 06-10-2004, 23:20
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
I'm going to agree that something needs to be done with the yellow box, but I do like the box there. I think that if you do decide to keep it, it should be more pronounced. Make it stand out by changing the color a little bit more that the background. I'd suggest darkening it because it is in the forground, but play around with it and see what looks best.
Oh, and ditto on the links at the top.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 07-10-2004, 20:58
HFWang's Avatar
AKA: DarkWulf
#0115
Try number two....
rawr
Unread 07-10-2004, 21:03
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Ah, that's a lot nicer looking. The sort of grey pattern behind the FIRST logo is good, too, because it really doesn't match with that yellow background.
Team 1257
Unread 20-10-2004, 21:02
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Actually, can you EXTEND that grey pattern so it goes behind the rest of the yellow background? Just have it start fading in about halfway over and it would bring the whole bar together.
I assume you're going to slice this up in photoshop? or are these screenshots of it actually rendered in a browser?
I'd recommend darkening up the background images behind the three sections you have there. They're a little too dim (on my moniter anyway, it's kind of wierd about color).
Unread 20-10-2004, 21:09
HFWang's Avatar
AKA: DarkWulf
#0115
I have sliced and diced it (more like cropped and saved but I digress)... the MVRT site should have the new template, but apparently its down? So check out http://darkwulf.antietem.com/layouts/mvrt/ for the HTML-ized version.
As for the background images on the three sections, they're supposed to be very dim... that way you can read the text. (I'd love to make them brighter, but people were complaining that they couldn't read the text...)
rawr
Unread 20-10-2004, 21:21
Hmm pretty nice.
I'd still darken those images up a little bit. To me they're barely visable at all, the reminder is a <!>, the upcoming isn't clear at all, and suggested reading is a globe?
Again, maybe it's my monitor, but I think they'd look better a smidge darker.
A minor quip: the entire page isn't the full height of my browser in 1024x768, but the Copyright image is designed to go on the bottom, and the side shadows extend the entire height of the page to my status bar. Maybe you want a big div somewhere height=100% or something to push that bar down to the bottom? Of course, if you eventually add more stuff to those bar it'll push it down anyway.
Unread 21-10-2004, 13:49
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
What a great design. This is the first good looking FIRST team site I've ever seen. A couple things: you may want to say {font-family: "Gill Sans MT", "Gill Sans", sans-serif;} since the Gill Sans on Mac OS X at least is just called Gill Sans. Maybe even specify whether you want to fall back to Arial or Verdana. Also your background is screwy (see attachment.)
Unread 17-11-2004, 17:42
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
Good job man! Are you going to steal those two trophies from me
Make sure you port the extensive gallery section i had built for the older sites. I have the full backup for the old mvrt site. IF you need it let me know.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 17-11-2004, 22:14
HFWang's Avatar
AKA: DarkWulf
#0115
In case you were wondering... the MVRT website is temporarily at http://mvrt.wellnow.net/
rawr
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
On Game Design Matt Leese General Forum 38 30-04-2004 19:08
TechnoKat design usage, communicated with judges Andy Baker General Forum 13 24-03-2004 17:37
Design Sharing Rod General Forum 32 14-01-2004 22:00
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
