Go to Post We're 3 pounds over. Drill until the hole saw is too hot to touch, then go find something else to cut off while you wait for it to cool down. - Richard Wallace [more]
Unread 06-10-2004, 01:04
cvanwolbeck cvanwolbeck is offline
cvanwolbeck is an unknown quantity at this point
wheels
Team 1280 is working on a new drive train (new to us, anyway). We are looking for wheels in the 6 inch diameter range to use with stick-on tread. What have other teams used for wheels, short of turning them out of billet aluminum?
Unread 06-10-2004, 01:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: wheels
You might take a look around here http://www.robotcombat.com/marketplace_wheels.html
Unread 06-10-2004, 04:44
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: wheels
we have made 6 inch wheels out of inch thick ply (25 mm) then sticking three of them togetehr and covering them in rubber using a mould. This is very heavy for a wheel but you can cut out the middle, or use a thinner layer of rubber....
we did the same this year but we used 8inch wheels .... we had too much weight and grip and had to replace two of them with castors ... we couldn't turn as they had tooooooo much grip....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 06-10-2004, 13:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: wheels
Traditionally, Woburn has used sheets of birch plywood (12 mm thick per sheet) and laminated them together into squares. The centre bores are drilled, and rough circles are scribed and cut out. They are then lathed to the appropriate diameter (between 6 and 8", depending on the year) and thickness (usually about 1.5"). Six lightening holes are drilled with a large Forstner bit, and the wheels are painted to resemble metal (just for the hell of it...). Depending on the year, some sort of conveyor belting is often attached for tread, but the pattern varies, depending on what's needed and what's available.
Unread 06-10-2004, 20:26
Re: wheels
Sounds interesting. What so you do for a hub?
Unread 06-10-2004, 20:51
Re: wheels
It is the hub.
Think of it as a primitive bushing. Woburn has used a 0.5" bore on the drive wheels for at least the last five years, each time using a wooden wheel with no special hub. It hasn't failed yet. The shafts are usually embedded in needle bearings or bronze bushings, and are free to rotate independently of the wheels (since the sprockets are themselves bolted to the wheels, with spacers as necessary). Last year, confronted with the need to save weight, instead of ground mild steel shafting, Woburn used 6061-T6 aluminum shaft from Home Depot. It was perfectly acceptable for the 3.5" wide wheel wells.
Unread 07-10-2004, 16:34
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
Re: wheels
haha i just asked Neel today how Woburn made their wheels
Who Likes Wheels? Rob Technical Discussion 22 06-05-2004 23:49
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
wheels, wheels, wheels.... Jesse Control System 1 05-02-2004 15:00
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
