Re: Speed controllers....
5 Victors sure is worth a lot... |
You have the fans hooked up to the input side, right?
If they're hooked up to the output, they will not be funninf at full power most of the time. |
If you have killed that many, you are either the most unlucky team on the face of the robosphere and you have some how managed to incite a fiery vengence against you from the robot gods or you are doing somehtign wrong. I have put those thigns through alot of abuse including running them at about 20 volts instead of 12, dropping them etc and have never had any problem.
I have to say, in 5 years, I only seen one bad speed controller. Last year we got one that would not produce output, but IFI replaced it quickly.
On a side note, if you want some to experiment with, I have some older 883's that my team would part with cheaply. (the money going back into the teams funding) They are not competition legal, but might be better to test out the problem then frying new legal ones. |
| initialization program and speed controllers | rosebud | Programming | 15 | 05-10-2004 03:35 |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 26-04-2004 21:27 |
| speed controllers & circuit breakers | deuceswild | Electrical | 2 | 15-01-2003 14:46 |
| speed controllers | archiver | 2000 | 5 | 24-06-2002 00:19 |
| Calibrating speed controllers and joysticks | thedillybar | Technical Discussion | 4 | 11-02-2002 13:24 |
