Go to Post I hope you realize that by starting this thread you have earned yourself a permanent place at the "WOEWITWISTFT" ("What On Earth Was I Thinking When I Started THAT FIRST Trend?") table. It's members are few, but the conversation is the most honest and amusing in the entire place. ;) - Jessica Boucher [more]
Unread 06-10-2004, 20:33
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: chains
Originally Posted by JVN
I think most teams that have trouble with #25 chain, don't actually exceed it's tensile load strength, but in actuality just throw it off the sprockets.
Woburn in 2003 was an exception--the #25 chains, though tensioned correctly, were used with too small a drive sprocket (18 tooth, if I remember correctly), and too powerful a gearbox (3 motors each, approx. 2.8 HP total, before efficiency losses). The individual links stretched to failure, probably as they were passing around the drive sprocket. It's unknown whether the rigid idlers further stressed the chain.
For information on the proper use of chain at various speeds and horsepowers, with various sprockets, consult the Tsubaki Chain catalogue, specifically pages A-1 through A-7 (Acrobat pages 12-18) of Section 1: Drive Chains. There's a chart which will allow you to determine whether the design you're working with needs #25 or #35 chain.
Let's just say that the 2003 Woburn drivetrain performed exactly as Tsubaki predicted...we had doubled the acceptable maximum power for the chain. 13 broken chains later, it was decided that the next robot would probably need to use #35.
Unread 06-10-2004, 20:51
Hinkel Y.'s Avatar
Hinkel Y. Hinkel Y. is offline
Hinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura aboutHinkel Y. has a spectacular aura about
Send a message via MSN to Hinkel Y.
Re: chains
The chains for Blizzard V never broke, but the same can't be said about the gearbox...
Unread 06-10-2004, 21:59
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: chains
I think we would all rather have a chain break then the gear box, although if everything is designed right, a key should break first before too much damage is caused to any key hard to replace component, or at least you would hope. I like to build everything strong enough, and robust enough to not worry, but the drill motor gear boxes where my weak link last season, but we powered along, and did a lot of pushing just with he cims, sometimes I would swear the drills had to be helping out the cims, but then I'd get it back in the pits, and sure enough, we would have wrecked another set of drill gb's. (plastic lock rings)
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 07-10-2004, 11:13
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
Re: chains
ok, I would like to thank all for the replies. Now, I read the thread that Steve W suggested and was wondering if anything came out of the tread design that Adam Y. was designing.
Unread 07-10-2004, 11:37
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: chains
I think in that thread, Adam was talking about an attachment chain style tank drive. Though I'm not sure about his particular results, I KNOW FIRST has seen this design many times in the past...
The Technokats - Team 45 made attachment chain treads famous.
(Some refer to them as "Techno-tracks")
Refer to their 1999, 2001, 2002 robot designs.
Many other teams have used similar systems as well.
Wildstang 2002 used a chain tread in their drop down tank.
(Why choose between a swerve and a tank drive? Just do both! Crazy!)
These "mean metal treads" aren't seen in FIRST anymore due to limitations on metal interacting with the playingfield. Some teams have modified their chain treads with non-metal cleats. (I believe the pictures I link to, are from team 885's 2003 robot.)
Many teams now prefer timing belt style treads.
I believe (from what I've heard from 45) when using a chain drive, difficulty often arises in keeping the chains from throwing off their driving sprockets. Side loads during turning will cause the chains to walk off their sprockets despite tensioning. When one uses timing belts, this problem still arises, but can be overcome by using timing belts with some form of built in, central allignment.
The merits of using a track drive, and of using various drivetrain types has been WELL discussed. Feel free to search previous discussions of these topics for more information.
It all boils down to simple physics!
Hope this helps,
John
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 12-04-2004 14:21
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
967 visualization tinsLee123 3D Animation and Competition 9 12-05-2003 15:22
chains in 3ds tinsLee123 3D Animation and Competition 4 17-02-2003 00:14
chains enjoiwheels Inventor 0 08-02-2003 19:33
