Go to Post Nothing's more memorable than giving someone a foul mouthed clown :cool: - Dave Scheck [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 13-10-2004, 00:22
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: PHP question
I got my first taste of PHP at www.w3schools.com
Then I later bought a book. I run my own forums and so forth, I'm guessing that the LED thing works by basically: when the user logs on, set a value in the SQL database to "on", so when you call a page which display's the username, it will show the online image (which is the green LED). When the user logs off, the opposite happens and you see a red LED. May sound confusing... I can't think of any better way to put it.
And I could be very very very wrong.
Also, you're still going to need to use some HTML when writting your own PHP scripts. Maybe you can try googling for a script that does what you want?
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
openFIRST PHP 5 Compatibility Timothy D. Ginn FIRST-related Organizations 0 30-07-2004 13:45
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
PHP Question Joshua May Website Design/Showcase 9 11-06-2004 20:50
PHP Question Raven_Writer Website Design/Showcase 2 22-05-2004 18:42
What's better, PERL/cgi or PHP/my_sql? mikefrei Programming 10 27-05-2002 22:50
