Re: gliding wheels....
i don't think that would fry your speed controllers but here are 2 options for you. what you are talking about is called a coaster and you can buy basically hubs and have them re-spoked for small wheels, this will work but don;t expect to be able to have back wards on your robot because there is no clutch in them that you can engage and disengage.
a better option in my mind is if you need to push the robot around design a quick release somewhere in your drive train and disengage the wheels from the motor. the quickest way i can think of is a decent cotter pin that you can pull in and out. but even better then that is make a cart. if you design a light cart there is no reason you should push your robot around, even though i doubt that spinning the motor back wards would cause enough current to cause any damage. |
our mentor suggested using the base of our crate for a cart.... i really disagree though ... as i dont think its practical as we have to mess around rebuilding the crate etc at the regional. . . .
i know we generate a bit of power as when we move the robot, it powers up the control board ...for some reason the fets keep blowing up on the speed controllers and we really can't afford £50 a time... |
its called a Sprag clutch. its basicaly a rim with inner teeth. and a shaft with spring-loaded arms that grab those teeth in one direction but are depressed in th other direction.
The only thing that I can think of that would allow this is a clutch like in a car with a manual transmission. There are one-way clutches that would allow you to free-wheel, but only in one direction, and I am not exactly sure how a bike hub works to allow it to free-wheel in both directions.
One thing that might work is a centrifugal clutch. We have one on the mini-chopper that my friend and I built. It is mounted on the output shaft of the engine and lets the engine idle up to a certain speed. When the engine speed increases, there are clutch shoes that move outwards and grab the drum around them to turn it. There is a sprocket already attached to the drum. I do not know if there is a cenrifugal clutch that would work on a FIRST robot due to the speed and torque required to engage it, but it is something to look into. |
Are your speed controllers in brake or coast?
#7
Good question! Stephen, I'd recommend contacting IFI directly and discussing your problem with them....ie frying Vics. They are a very patient and talented bunch. Technical Support Hotline - 903-454-1978, hours are 9am to noon, 1pm to 5pm CST. (...so I'd guess you ~5hours ahead) (The EE's on these forums are also top-notch. A PM might yield an answer to you vexing problem) Eric |
#8
Anyways, there's a large number of things you can use for a cart. If a little red wagon is still too big, get or make a 4-wheeled furniture mover. it's a square of flat 2x4's with four casters on it. Your cart can be as simple or fancy as you require it to be. If you're still wanting to just push the robot around, get a couple of quick release connectors. Run the outputs of your speed controllers through these before they go to your motors and just pull them whenever you're going to push the robot around. |
#10
What you're describing on a bicycle is a one-way or Sprag clutch as Tytus already answered. These are a bad idea for your robot because they would only allow it to be powered in one direction; that is, you'd never be able to go in reverse.
I think you'll find it's much easier to build or buy a small cart than it is to engineer "neutral" into your drivetrain so that you may push it around. |
#11
We put our cart in the crate with the robot. Wetzel |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Going over 6 inch step with 12 inch wheels | Joe P | Technical Discussion | 25 | 12-04-2004 11:15 |
| wheels, wheels, wheels.... | Jesse | Control System | 1 | 05-02-2004 15:00 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
