Go to Post You know FIRST is on the level of sports when you can give predictions like sports casters do. :) - RoboMaster [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 02-06-2001, 18:49
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
Question Button Bar
I have a question about the button bar.
Perhaps its just me, but it runs off the screen, causing a horizontal scroll bar to appear. Is there any chance you can rearrange the buttons (perhaps into an HTML table or use smaller button images) to keep the scroll bar from appear?
Otherwise, looks really nice! Perhaps you should have a contest to replace the vBulletin icons with some FIRST-oriented images.
Unread 02-06-2001, 19:15
Joel J's Avatar
Joel J Joel J is offline
do you..
A plausible solution...
One remedy would be to put the buttons below the Header Graphic like this:
...and center it at the top of the screen. What do you think Brandon?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 02-06-2001, 19:34
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
Arrow Change your resolution
The whole bar shows up on mine. Try changing your screen resolution. Personally, I like how it is now.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 02-06-2001, 19:50
It looks fine on 1600x1200
but yes, a new arrangement would be nice for those who aren't blessed with a recent video card and monitor
Unread 02-06-2001, 20:15
#0596 (SciClones)
It's just that the vBulletin forums have what is called a "liquid design". This means that it will flow to fit the window size. (Go ahead and try it out on the front page.)
The tables and text all reposition themselves depending on the size of their container element. In the case of the button bar, it 'breaks' the liquid design by forcing itself outside of the original table width.
This doesn't show up on higher resolutions, since the button bar can fit within the window container. On lower resolutions (800 x 600, for example), it becomes glaringly obvious.
Just a suggestion.
Unread 02-06-2001, 20:29
Lora Knepper Lora Knepper is offline
From the Land of Circular Weather
Lora Knepper is a name known to allLora Knepper is a name known to allLora Knepper is a name known to allLora Knepper is a name known to allLora Knepper is a name known to allLora Knepper is a name known to all
Send a message via AIM to Lora Knepper Send a message via MSN to Lora Knepper
Same thing happens to me
Same thing happens to me....I'm on 800x600 It somewhat annoying, but at least I don't have to use those buttons much.
~ lora
Unread 03-06-2001, 05:17
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Ok.
All fixed. It will wrap now if it doesn't fit on the screen.
I run at 1280x1024 on a 19" monitor, so i didn't notice any size problems
sorry
Brandon Martus
e-mail
Unread 03-06-2001, 12:02
Thanks Brandon Maybe one of these days I'll get a bigger monitor so I can run at a higher res
~ lora
Unread 04-06-2001, 20:27
The new bar looks great!
It still looks best at 1024x768 and above, but it wraps now at lower resolutions
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
Select button and user mode n[ate]vw Programming 2 20-01-2003 16:33
Can your robot go under the bar? Scorpion515 General Forum 27 15-01-2003 22:39
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
