Go to Post FIRST isn't about building robots. I know. But I also know that Inspiration comes in a lot of flavors and I, for one, believe it is a lot easier to inspire my kids when we set "playing after lunch on Saturday" as a worthy team goal. - Joe Johnson [more]
Unread 12-10-2004, 15:33
occra 23.
AKA: ryo
None #1481
rack and pinion.
has anyone tried to use a rack and pinion mechanism on their robot before? well, with a cylinder pushing the rack. not a motor spinning the pinion. that ive seen. also seen screw drives or w/e theyre called.
so, i would like to create a rack and pinion mech. few problems tho.
1. this is for the OCCRA competition. and in its rules it states NO precision tools allowed. ex) no cnc.
2. well, theirs lotsa rules, but mainily, unless we can hacksaw a flat gear rack from angle aluminum, we'll hafta use a chain as the rack.
3. no welding.
so, first q.
how to mount a piece of chain securely with no slippage to a piece of flat or angle aluminum without welding.. i was thinking zip ties, but i hope sumonell think of sumthing a bit more reliable.
next. how to keep the "rack" straight without falling off the sprocket. (remember, the "rack " is connected to a cylinder.)
and then the main question. is this gonna work?
so, anyone ever tried this idea of creating a rotary force with a cylinder before? we need a minimum of 140 degrees of motion. our cylinder we chose is a 2in stroke. so with a small sprocket, cant be too hard. except the chain may break? i dunno.
ps. no rotary cylinders in our kit...
well, we hope sumone can tip us on what would be difficult, improbable, easy "shortcuts" or even a picture of an example, it would be greatly appreciated.
main point.. we want help!!! aaand oh, one more problem. our first competition is coming up REAL soon!
Unread 12-10-2004, 16:01
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: rack and pinion.
If you would be ok with using a cylinder with significantly the force that you actually need, you could wrap the chain part way around the sprocket with one end connected to the piston and the other end connected to a spring with a fixed mount. You would waste a lot of force (half the force?) tensioning the spring.
If you only need 140 degrees of motion, a better solution is probably to attach the cylinder to a spool of some sort with a cable. If i'm not mistaken, the maximum amount of force the cylinder produces will be applied through the whole 140 degrees as opposed to using a fixed linkage (like a cam).
Team 1257
Unread 12-10-2004, 16:50
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
There is a chain that has mounting points on it. From there you could bolt the chain to the piece of angle aluminum.
Unread 12-10-2004, 18:01
occra 23.
AKA: ryo
None #1481
yes. i think thats a easy way. and then ill have to do sum math about the force of our cylinder. ill look into it. thanks!
uhh. cant quite picture it. sorry. a simple paint sketch might help me. sorry im incapable.
and then i have to add, i want this compact.
i doubt we are allowed any other kind of chain than the "normal" ones. sorry. OCCRA rules are pretty tight. thanks for the reply tho!
Unread 12-10-2004, 18:55
mgreenley
Posts: n/a
For this years FIRST robot (Daisy III) we actually used some 35 chain as a track to run our arm on. You can simply use screws or bolts (1 or 2 on each end) through the part of the chain that a gear tooth normall runs. Bolt it to some oak wood or alum. or the like and off you go! If the chain needs to be more taught, then use a router to put a recess in the material (wood or delran is nice) and then bolt it down.
Good luck with your project, Michael Greenley, Team 341
Unread 13-10-2004, 21:13
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Try mounting th echain inside a piece of u shaped aluminum track. Something like what mounts to the wall for an adjustable shelf system. You can buy the track at most hardware / home stores. Cheap.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 13-10-2004, 21:47
occra 23.
AKA: ryo
None #1481
again, i cant quite imagine what you are trying to tell me.. a quick paint sketch would be lovely.
Unread 13-10-2004, 22:14
Ian Mackenzie Ian Mackenzie is offline
FRC #3683
Ian Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond repute
How about something like this? Putting the chain around an idler (which could be as simple as a little bronze bushing on a bolt) avoids the need for elaborate tracks and ensures the chain stays in contact with the sprocket. It should be pretty easy to put a bolt or something through one link and attach it to the end of the piston with a bit of aluminum angle.
Piston and chain mechanism
EDIT: I don't know what's up with that thumbnail, but it doesn't look a whole lot like the actual image...
Unread 13-10-2004, 22:31
Fold em oval!
And the same thing can be done with a cable and pulleys instead of chain and sprocket. The obvious advantages to cable are lighter overall weight, cheaper, and adjusting length is easier (use a turnbuckle). Are there any advantages to using chain?
Team 1257
Unread 14-10-2004, 15:27
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
You could use the chain in the traditional sense, with 2 sprockets and the chain running around those like you would with a motor powered sprocket then attach the rod of the cylinder to the chain in the middle span between the sprockets. This way the cylinder powers the chain in both directions without using springs, ect. If you want a good example of what I mean go look at the curtains on your stage.... 2 pulleys, and your hand grabs one of the ropes, you can either pull down on it or push up on it (which actually pulls the rope up) this way your arm is powered in all directions of movement, which I have learned is a very good thing, gravity is nice, but with cables and such which can tangle when they become slack I prefer to power them in both directions.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 16-10-2004, 00:21
Rookie Year: 1942
Try this ms word picture. Hopefully it helps. Also, try a home store. Ask for small metal shelf hardware - slotted channel for the wall and metal shelf brackets. Should be easy to find.
Edit: go to www.lowes.com
Search for item 117881.
Chris Fultz
Unread 16-10-2004, 00:32
Fold em oval!
If you complete a loop with the cable/rope, there is no problem with slack (rather, just about as much problem with slack as you would have with chain) So, again, I'm not sure why one would use chain in this situation.
Team 1257
Unread 29-10-2004, 07:26
Green,
There are several good suggestions, I like Chris's chain in a "U" extrusion as a simple and effective approach. But a simple and lighter alternative is to wrap the chain around a sprocket (180 degree wrap) and terminate in a spring. The spring holds tension on the chain as the cylinder moves the sprocket. There is no need to have a bearing surface under the rack and no reason to hold the chain in alignment since that is automatic. This is similar to the loop approach discussed but doesn't add the weight of the second sprocket, bearing, and extra chain.
Unread 29-10-2004, 08:27
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
One of the best chain rack and pinion designs I have seen in FIRST was on the ChiefDelphi 2000 robot. Its purpose was to entend and retract their boom-like arm. Here is a picture.
I wish I could find a picture of the back face of the robot. This view would show that 2 van door motors drove a chain up and down. The chain was attached to two aluminum tubes and was wrapped, serpentine-like, between sprockets on the 2 motors.
Can anyone from CheifDelphi give us a better picture of this?
This machine was and still is a thing of beauty. It is my favorite robot in all of FIRST, for all time. This design feature was just one of its strong points.
Andy B.
Unread 29-10-2004, 10:16
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Superior Roboworks cloned the Chief's design for the 2003 season. We used two window motors and the system worked great!
When I find a good picture I'll put it up. It's just like the Chief's so you can get what Andy is talking about.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
