Go to Post Such is life in the fast-paced, laugh-in-the-face-of-adversity, never-let-them-see-you-sweat, sometimes-you're-the-windshield-sometimes-you're-the-bug world of FIRST Robotics! - Sean Schuff [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 14-10-2004, 22:33
Mr. Mac Mr. Mac is offline
#0001 (Juggernauts)
Mr. Mac is on a distinguished road
Re: [OCCRA]: drill transmission
Originally Posted by greencactus3
we got the jammed gear selector to move now. now just the problem of the clutch slipping... this is for the dewalt one.
and both the drill transmissions of handdrill and the drive motor are slipping.
Something is probably preventing the clutch plates from seating themselves fully. I'm assuming that you have the torque collar set to the drill position (as marked by the icon on the collar) and not one of the torque settings. If the transmission was ever taken apart, you might open it back up and see what pushes the plates together; in the Bosch drills we used to use there were ball bearings that, if dislodged from their nests, would prevent the plates from engaging. Make sure that nothing is inside and that the clutch plates still have the clutching indentations facing each other. In the meantime, I've sent a new drill to your school.
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
Drill Motor Transmission Help aznbomber Motors 12 09-03-2004 20:38
CAD of Bosch drill motor transmission? Crazy Inventor 7 21-01-2004 12:03
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Mating gear with drill transmission thedillybar Technical Discussion 0 13-02-2002 21:08
