Go to Post Sometimes the best hiding places are in plain sight. - Robert Cawthon [more]
Unread 15-10-2004, 03:29
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Cool 2001 OI Question !
The topic says it all =)
Ok heres my issue:
about a couple of years ago the team i was on went to a little event held in another high school, brought the robot along everything was fine, go to pack up the OI and its corresponding gear and some how the DB9 cable going from the modem to the OI nearly ripped off the DB9 from the OI. Ok manage to rig it so it works temporarily. 2 years later robot is still in use but no OI! why? because the DB9 connector (for the radio) came off the OI. Ok I bring it to a friend at work who knows ALOT about circuitry and how to solder. He replaced the DB9 for me and fixed any damaged circuitry to the board.
My problems are as follow now:
1) The search / TX light no longer comes on / blinks only the Power on and No Data Radio comes on!
2) no power to the modem
What was Done!
Number 1 happened before when the original DB9 Connector was accidentally torn off and assumed by changing it it would work again.
Number 2 after I got the OI back from my friend I hooked the modem up and checked it - No power to the OI I did a couple of things to check this.
1a Tested for continuity between the DB9 connector on the board and the circuits it led to on the back of the board -ALL OK
1b Tested for continuity between the DB9 Cable and the ciruits that it led to on the back of the board - ALL OK
1c Radio Modem was working before all this and after all this and has not been in anyone elses hands but mine since the repair of the OI.
Im gonna guess that maybe the Search / TX light on the OI is burnt out - I doubt it but thats the only thing I can come up with esp. since the fuse works fine.
Any suggestions. on that issue
for the modem I can only assume that maybe one or more of the circuits on the OI may not be making proper contact
Does anyone know where I can get blueprints for this board other then Innov. FIRST / EWave. I doubt theyll give me the papers =(
Are there any TestPoints on the OI to check?
All I know is that I need HELP =)
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 15-10-2004, 05:41
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Re: 2001 OI Question !
Ok heres my issue:
What was Done!
in the socal regional due to issues with space our RC was left exposed and in one of our matches the robot tipped to its side and cause the rc to hit the ground... the ds9 cables for the radio were on the side that hit the ground. it imediately broke the connector off with a bunch of exposed pin connections. so our robot didnt function for a whiles. i took the rc home and soldered a ribbon cable with the matching connector terminal .(radio shack and other places u can get one, tho in particular i got mine from an old old old pc.. so look there too) tested continutiy and it checked out pretty good, tho i believe that one of the pins over layed a lil in the solder so it cause to not start up the radio and gave me a blinking red light for that on radio, broke apart the solder and fixed and it was good as new(tip: dont test at solder points test at the terminals) i dunno how useful this story is for you. but i do have another
when we received our 2004 parts i remember trying them out with old ds9 cables that worked (tested out later on an older robot) and the cables simply didnt function with the 2004 gear and i checked for the visa versa and it was proven like wise. so make sure about the cables and the year of cables your using they have seem to vary with first and functionality. i guess there different some how though i dont know how. i also tested this out by just getting a normal serial cable for my pc and the frc stuff didnt function with it so check your cables even if there good. there tricky
Plus i have a few more test for you
1. 2002 and 2001 are very alike if not identical so, trade in radios and or OI's and even cables and trial and error all of these to make sure what part is truly the problem(you may be suprised but with less headaces)
3. (im not sure if u did this or not) dont just test the continuty from radio to OI but instead check continuty also from pin to pin, if there is bridge in there some where even one u cant see it might fry the gear or might just make it malfunction, as good as anyone is with a solder they can always mess up
4.You can break it apart again and build up again like i did
hmms the peeps at Innovation First are awesome they even have program to fix your FRC stuff or trade it if im not mistaken (at cost of course) but 2001 stuff is very iffy several years later, and i dont expect them to give you blue prints but u should review the manual for 2001 or 2002 anywhere u cna find it to find out exactly what the Oi is telling you and if it can truly coencide with your setup
-Osc-
wow that was long.. hope it helps some
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Question of the Week!!! (8/24/04) Andy Grady General Forum 27 27-08-2004 19:00
Question of the Week!!! (6/14/04) Andy Grady General Forum 23 01-07-2004 15:54
Question about 2001 nationals slavik General Forum 4 12-01-2004 21:39
Follow-up to 2001 Nats Mars Launch dlavery Chit-Chat 2 22-10-2001 20:45
2001 Scratch Awards Andy Grady General Forum 12 04-10-2001 22:04
