Go to Post FIRST is not about building robots, it is about building people; the robots are just a good way to get the people there. - JamesBrown [more]
Unread 15-10-2004, 22:17
Bharat Nain's Avatar
Create a low speed drive in programming
Our robots are a little too fast for anyone other than the driver to control. Since we take our robots out for demos and stuff, I being the programmer would want it to be safe. So I have been trying to come up with a program to drive this thing at half speed when the joystick are at full forward. We can't just divide all the values by 2 because that moves the center from 127 to 63.5. Anybody done such a thing, or can come up with a working program for this? I would appreciate any help
Thanks,
-Bharat
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 15-10-2004, 22:26
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Re: Create a low speed drive in programming
You can divide by 2 then add 63.5.
[edit]
You might want to tweak that reduction ratio a little, though. For example, you might want to multiply by 2/3 or 3/4 instead of 1/2. Whatever you decide to do, you can recenter your range by adding whatever it takes to get your center back to 127.
So a formula would be:
x1*reduction_ratio + (127-127*reduction_ratio)
And the same for y1
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 15-10-2004, 22:31
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Two simple ways that I can think of off the top of my head:
1. convert the speeds to signed values then divide by two:
int signValue(int value)
   	return value - 127;
divide by two then:
int unsignValue(int value)
   	return value + 127;
2. This one allows for some interesting possibilities. An open-filter system.
char filter[255] = [64,64,65,65,etc,etc];
   motorOutput = filter[joystickInput];
You can simply fill the filter array with [64,196] (middle 50% of speed range) in with a constant slope, or you can experiment with having a curve to, for example, put values near the center closer together to give even greater very low speed control. In fact, you may decided to leave the full range of possible speeds, just make it so the joystick has to be at the far extremes to reach full speed.
Team 1257
Unread 15-10-2004, 23:56
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
wun will become famous soon enough
Send a message via AIM to wun Send a message via MSN to wun
Thanks,
-Bharat
Another good way is look up tables. Then you can also set it up so it "ramps" (eg: if you move the joystick 1/2 of the way, it will only bring it up to 1/4 the possible speed, then when you push the joystick all the way, the robot will go up to 1/2 speed (or what have you). The code would look something like this:
const rom unsigned char mytable[256] = {
     56,56,55,55....
I wrote a little python script (which I promptly lost) that would generate them for me. There is also an auto-generator here (but your gonna need M$ excel to open it =\)
Help Microsoft stop piracy. Use Linux!
I have three gmail invitations, message me if you want one
Unread 16-10-2004, 14:52
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Or perhaps have it divide the difference from 127 in half, add/subtract them and send that to PWMs
Like if your joystick is at 250
250 - 127 = 123 / 2 = 61.5 + 127 = 188.5
int DriveLimiter(int joyvalue)
	if(joyvalue > 127)
		return ((joyvalue - 127) / 2) + 127;
	if(joyvalue < 127)
		return 127 - ((127 - joyvalue) / 2);
I just did that off top of my head, don't shoot me if it's wrong, but that's the general idea. I think.
Matt Krass
Unread 16-10-2004, 15:06
Fold em oval!
Just to clarify, my second method is the same as Wun's and my first method is (essentially) the same as Matt's.
Team 1257
Unread 16-10-2004, 15:30
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
One year, we had our programmer's make it so the dial on the joystick controlled this scaling factor. This allowed the robot max speed to be dynamically adjusted.
I just do the gearboxes. Any programmers wanna explain how this is possible?
John
Unread 16-10-2004, 17:54
Fold em oval!
Well I'm not sure what dial you are referring to, but I assume it is a one axis analog input. You could simply multiply the joystick input by a scaling factor (of course after first centering the joystick input around zero by subtracting 127) based on the value of this dial. It would probably be something like this (using the functions from my first example):
motorOutput = unsignValue(signValue(joystickInput) * (dialInput/255));
That is a pretty cool feature, but I think an open loop filter on the inputs should probably give you enough control without doing that.
Team 1257
Unread 17-10-2004, 01:09
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Here's another possible solution.
motor=y-((y-center)/factor)
So for example:
y=168 center=127 and factor=2
148=168 - (( 168 - 127 ) / 2 )
'y' is the joysticj y-axis, center would be you center value for that joystick(normaly 127) and factor could be changed to scale up or down the output speed.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 17-10-2004, 12:54
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Originally Posted by scitobor 617
So for example:
This code will not work for joystick values less than 127.
Unread 17-10-2004, 12:56
Carpe diem
The wheel that John is talking about was on the old joysticks. It was a thumb wheel located opposite the y axis trim adjustment wheel. The input was analog and reffered to in the code with a variable name similar to "thumb_wheel."
Here's the code to have the thumb wheel control the scaling on a joystick input.
if (joystick < 127) {
     motor = 127 - ((127 - joystick) * (thumb_wheel/254));
} else if (joystick > 127) {
     motor = 127 + ((joystick - 127) * (thumb_wheel/254));
Unread 17-10-2004, 20:38
wun's Avatar
wun wun is offline
AKA: David Wolever
#0865 (Warp7)
Now, I'm not sure about this, but I know the PIC processor is not very good with things like division. This makes me wonder if it would be faster to generate a lookup table before hand, or if the overhead of the division is so minuscule it will not make any real difference.
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
