Go to Post I, being a Trekky myself, will really enjoy a Star Trek themed game if it turns out to be that. I will not enjoy programming the alcubierre warp drive. :D - AveryLevin. [more]
Unread 14-10-2004, 19:40
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
No Signal From Gyro
First, thanks in advance for taking the time to read this. Here is our problem. For the past week we have been trying to use a gyro to help our robot go strait in autonomous control. We have 2 Gyros and we wrote the code for the EDU bot for initial testing and have 2 working gyro control codes. So we thought it was time to impliment them into our competition bot from last year. Basically we just copied the code from the EDU bot into the User_Autonomous function in user_routine_fast.c on our competion. Here is 1 version of the code we put in that worked perfectly on the EDU bot:
//CODE OMMITTED FOR POSTING PURPOSES
//Gyro Variables Located at top of user_routines_fast.c
long int gyro_input;
long int gyro_error = 0;
unsigned int left_speed = 175;
unsigned int right_speed = 175;
#define LEFT_START_SPEED 175
#define RIGHT_START_SPEED 175
#define ACCEPT_ERROR 70
#define TURN_SPEED 1
void User_Autonomous_Code(void)
  /* Initialize all PWMs and Relays when entering Autonomous mode, or else it
     will be stuck with the last values mapped from the joysticks.  Remember,
     even when Disabled it is reading inputs from the Operator Interface.
    pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
    pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
    relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
    relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
    relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
    relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        /* Add your own autonomous code here. */
		//START GYRO CODE
		gyro_input = Get_Analog_Value(rc_ana_in01);//Get the value
		if((gyro_input<505) || (gyro_input>520))//Cusion
			gyro_error += ((int)gyro_input - (int)523);
		if(gyro_error < -ACCEPT_ERROR)//Too far left
			if(left_speed <= 250)
				left_speed += TURN_SPEED;
		else if(gyro_error > ACCEPT_ERROR)//Too far right
			if (right_speed <= 250)
				right_speed += TURN_SPEED;
		else if((gyro_error < ACCEPT_ERROR) && (gyro_error > -ACCEPT_ERROR))//Going back on course
			left_speed = LEFT_START_SPEED;
			right_speed = RIGHT_START_SPEED;
		pwm13 = left_speed;//pwm13 goes to left motor
		pwm15 = right_speed;//pwm15 goes to right motor
		printf("Gyro: %5u Error: %5u PWM13: %5u PWM15 %5u \n",(int)gyro_input,(int)gyro_error,(int)pwm13,(int)pwm15);
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Thats everything i modified in the default code for the FRC. The problem comes at Get_Analog_Value(). It is not getting an analog value, it is just coming up 0 in the printf (which printed fine on the EDU bot). We have really tried everything and it never gets a signal, we tried it on both gyros we have, we tried many different rc_ana_in ports, we even tried plugging the gyro in backwards and into the digital ports =P. Nothing makes it display a value. Is there some place where you have to initialize something to let you use rc_ana_in01 like in the EDU code. We are really stummped and very frustrated and ready to throw out using the gyros.
Thanks again for your time.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 14-10-2004, 20:44
Re: No Signal From Gyro
Your analog I/O should already be setup in User_Initialization() in the user_routines.c file by the statement:
Set_Number_of_Analog_Channels(SIXTEEN_ANALOG);
I think Get_Analog_Value returns "unsigned int" if I recall correctly, so you might want to typecast the call to “(long int)”.
Will you be at the SBPLI mini-comp tomorrow? If so look me up and I'll help you debug the gyro input.
Unread 14-10-2004, 20:59
AKA: Ken Colton
FRC #0527
1.) We have that Set_Number_of_Analog_Channels() in there
2.) We have tried to type cast it to every variable known to c =P
it would just be
gyro_input = (long int)(Get_Analog_Value(rc_ana_in01));
right?
3.) Nah, we wanted to go to the mini-comp but could not afford the cost of a bus since the district busses would still be on duty.
FIRST Volunteer
kcolton@gmail.com
Unread 14-10-2004, 22:12
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
This is going to sound a bit whacked, but try getting rid of:
and try just mapping your motor outputs to pwm's 9-12 or anything but 13-16
I think we ran into something similar last year and finally tracked it down to using the Get_Analog function in conjunction with the Generate_Pwms
In the FRC, PWM 13-16 aren't output from the same microprocessor as the others and this seems to create some kind of conflict.
Eric
Don't PANIC!
S. P. A. M.
Unread 14-10-2004, 22:45
it would just be
right?
You got it right.
Does the gyro still give you a proper reading on the Edu controller? Just to make sure it didn't develop a loose connection (although doubtful since you tried both).
What model gyro are you testing?
If your team meets after school I could take a late lunch or drop by after work (in Bethpage) if you can't isolate the problem. I hate the thought of you giving up the gyro after you got it working on the Edu.
Unread 14-10-2004, 23:50
AKA: Dr. Brooks
no team (WRRF)
We use analog feedback for our arm, and a gyro to control turns
on our robot. The cast on the GetAnalogValue() call is not required,
because the routine is declared somewhere,
but the cast for arguments to printf is, because "char" will otherwise
get pushed on the stack, for efficiency purposes, I presume.
We have the "generate pwms" call commented out in our code, and
use only the "normal" pwm outputs, it being general policy to comment
out anything that might be considered "exotic" and a cause of possible
trouble. I think that the "Keeper of the magic 8 ball" has it right
on this question... Pitch the "generate pwms" and go for the normal
pwm outputs.
Unread 15-10-2004, 19:41
AKA: Ken Colton
FRC #0527
Ok, here is the latest updates from our Attempts at getting a signal from the Gyro. Here is all our autonomous code is:
//VARIABLES DECALARED AT TOP
unsigned long int gyro_input;
        printf("gyro: %d",(int)gyro_input);
And we get in out output from the printf "Gyro: 0". I can't make it any simpler! and its absolutly driving me up a wall! What could possible be wrong other then our FRC hates me and is broken in some way....does anyone out there have any thoughts on why this thing might still not work. Even if its something incredibly simple that you assume all teams should know please tell. Thanks again.
I also remember right before the 2004 competition FIRST released an unpdate for the controller that we never did.... did that have anything to do with analog inputs?
PS. Currently we are meeting after school on Fridays @ 2:00pm, and we sometimes meet during the week just to work on some small things, so if we cant get it working soon maby it would be best if you stop by and have someone who really knowns what they are doing (ie. not ne one from our team) look at it.
FIRST Volunteer
kcolton@gmail.com
Unread 15-10-2004, 22:53
FRC #0180 (SPAM)
...hmmmm, I know you're only posting part of the file, but have you #included:
ifi_aliases.h
ifi_defaults.h and
ifi_utilities.h at the top of the file?
Without them you're missing the function prototype and definitions for
.....just a thought...cause that'll hose it up
I don't see any problem with your print, but I would make gyro_input an unsigned int to match the return type in the function prototype.
Hope that helps,
Eric
Don't PANIC!
S. P. A. M.
Unread 16-10-2004, 15:11
The RC firmware update innovation-FIRST posted doesn't affect this problem. That had to do with initializing PWM & RELAY values when changing modes.
Nothing looks bad in your code and the failure to typecast in this one case shouldn’t be noticable, so lets go deeper.
I’ve attached an entire FRC project from the default code with two analog read statements added to Process_Data_From_Master_uP() for no other reason than that routine was handy (I posted just that routine below-those are the only changes made to the default code). Test with the whole project to eliminate the chance that something elsewhere in your code is causing the problem as Eric says.
You'll see one statement reads from analog input 1, the other from analog input 16. I tested with our gyro on input 1 and with a potentiometer on input 16. You don’t need to have a pot handy. The Get_Analog_Input will return “1023” if nothing is attached to the input pins, and if you connect the “SIG” and “BLK” pins with a paperclip you’ll get a reading of zero.
Try testing with this. You can just IFI_Load the .hex file or recompile the whole project if you like.
void Process_Data_From_Master_uP(void)
long CurrentGyro=0;
int pot=0;
Getdata(&rxdata); /* Get fresh data from the master microprocessor. */
Default_Routine(); /* Optional. See below. */
/* Add your own code here. */
CurrentGyro = (long)Get_Analog_Value(rc_ana_in01);
printf("Gyro= %d", (int)CurrentGyro);
pot = Get_Analog_Value(rc_ana_in16);
printf("pot= %d", pot);
Putdata(&txdata);			 /* DO NOT CHANGE! */
You’re looking for three things.
1) If both analog inputs = 0 no matter what, even disconnected, that means bad FRC analog inputs, ergo the FRC hates you.
2) If the pot works, but the gyro doesn’t then the gyro hates you.
3) If they both work then something else in the code hates you.
P.S. Friday afternoons are good for me. Clear it with your advisor first then PM me directions both to the school and where I find the team at school. I'll be coming south on the SOB
Unread 16-10-2004, 20:34
FRC #0180 (SPAM)
..... I'll be coming south on the SOB
....I drive I-95 south to West Palm Beach, every day and it's an SOB too <ha!>
....anyway, your plan is a good one Mark. They'll get to the bottom of this and love that little gyro chip
Eric
Don't PANIC!
S. P. A. M.
Unread 17-10-2004, 18:34
AKA: Ken Colton
FRC #0527
Ok, the 2 differences in my code from yours is that
1.) I used global variables instead of local ones for gyro input.
2.) and I did not initialize them to anything anywhere
I don't know if that will cause any problems....but what I did notice was that the analog inputs gave 0 when nothing was connected to them, which makes me think the FRC is messed .... but what makes me think its only semi-messed is that when we hooked up a pot we were getting a reading from 0-6 corrosponding with the position of the "turny thing" on the pot. I thought that it SHOULD display 0-1023 like a good 10 bit unsigned integer, so either our pot doesnt like numbers above 6 or the FRC is broken.
I will load the code next available chance and tell you the results. But really, thanks for caring! =) Its always good to know that if you have no clue what you are doing there is someone out there.
FIRST Volunteer
kcolton@gmail.com
Unread 17-10-2004, 19:59
Won't make any difference. I only used locals to isolate the issue, and initialized them to make sure Get_Analog_Input was really returning a value.
The rest of your description doesn't sound good for the FRC, but run through the test. If the problem looks like the FRC, drop in reads and do the open/closed pin test on all the other analog inputs to see if they're all blown.
Also, test the range of your pot on the EDU to see if it behaves properly there. I'll bring my own pot on Friday if the problem doesn't get solved by then.
Unread 19-10-2004, 07:30
AKA: Ken Colton
FRC #0527
OK, the mentor said it is OK for you to stop by on Friday. I PMed you the exact directions and everything else you need to get into the building.
FIRST Volunteer
kcolton@gmail.com
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
Fading LEDs using a PWM signal from the Edubot DanL Programming 22 30-03-2004 00:07
Wierd gyro code problems...pls help Salik Syed Programming 4 14-03-2004 01:29
gyro code odin892 Programming 2 08-04-2003 14:50
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
