Go to Post What is this "off season" of which you speak? - Alan Anderson [more]
Go Back   Chief Delphi > Other > FIRST Lego League
Unread 20-10-2004, 11:46
paula paula is offline
paula is an unknown quantity at this point
bricxcc error
I´m working with NQC using bricx Command Center 3.3. The firmware I´m using is firm0328.lgo. All in a Windows 2000. It is a RCX2.0.
When I want to download a program, I always have this error message:
Compile failed
no (or invalid) reply from RCX
The problem is that if the programme doesn´t have subs or tasks (a part from the main task), it works. But if it has subs and tasks, the RCX doesn´t download it.
Can you help me? Do I need to install anything else?
Thanks.
Paula
Unread 20-10-2004, 14:22
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: bricxcc error
What version is the firmware on the RCX?
Unread 20-10-2004, 15:24
Re: bricxcc error
I took the firmware from Robotics invention System 2.0 de Lego Mindstorms.
I also tried with the one from LEGO Mindstorms SDK 2.5.
The file name is firm0328.lgo
Unread 20-10-2004, 18:39
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: bricxcc error
I'm thinking its a windows 2000 permissions problem.. I ran into a similar problem when trying to use it on my school's computer.. neither rcxcc nor the mindstorms software could see it. What type of IR tower are you using? I tried with the 9-pin serial one
XP doesn't have this problem, neither does win98se
Also know that I'm fairly certain you can only use the mindstorms software or robolab to program the actual model to use. And from what I've seen, robolab is more powerfull
Unread 21-10-2004, 07:44
Re: bricxcc error
I'm using an USB IR tower.
All right, I'll try installing a VMwhere with a Win98SE.
Thanks.
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
Error in Visual C++ Ashley Weed Programming 15 06-05-2004 14:53
Strange 16 bit MS-DOS subsystem error Crazy_Ed Programming 6 18-03-2004 14:31
strange error Anthony Kesich Programming 2 25-02-2004 18:55
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
