Re: Mechanical tips for rookies
Anne,
This is AWESOME. You're selling yourself short though... Rookie teams? I bet there are lots of veteran teams who could probably use a reminder of some of these principles from time to time as well. This is just good advice for ALL teams to take to heart. Thanks for posting! John |
Very true John, this is advice for all. I'll keep that in mind when I put the final list together.
As for the batteries, I didn't put them on this list since it is the mechanical list. Look at the electrical list and you will see it on there. Please keep the suggestions coming, the more info on this list the better. |
After a bit of chaos last year, our team was / is determined to have a full-functional prototype robot for the 2005 season. Maybe have it completed by the Third or Fourth week. It could be made from 80-20 or Bosch extrusion or even wood. There are some obvious increase in costs associated with this - but hopefully will allow for a more functional and tested robot in the end. Any idea how many teams are out there that already do this? Maybe 10%?
how about a tip on loctie and whats shouldnt be and what should be
always cut long , but never short (as in extra materail vs making short and useless) (One of Ours mentors really stress this) Tight Means Tight , Not how tight you could get it , and not striping and destroying parts, and not leaving it loose PVC Can be your friend ![]() ALWAYS Clamp it Down Right tool for the right job more to come... maybe |
weeelll, remeber, bungee is your friend, but always do the math to figure out if the cylinder you wanna use has enuf force to lift w/e. even if it works at 100psi, it doesnt matter if it doesnt at 60.
All,
The top of my list is to get a working/driving base finished first. It is needed for electrical to work on part placement, drive team needs practice and autonomous team needs something to mount prototypes on. Open gear transmissions produce metal flakes (grindage) so protect electrical circuits from fallout. Be aware of robot systems when drilling or machining parts on the bot. A square tube makes as good an electrical conduit as it does a support member. Your electrical team may have passed motor wiring through the tube you are drilling! NO GRINDING IN THE PITS! Besides it causing incredible noise, the flying hot bits are a real fire hazard. When a motor or other shaft does not have enough bearing (most do not) you must add bearings that can take the stress. You cannot hang a sprocket or wheel on the end of the chalupa motor shaft and expect it (the motor) to survive. Motors do draw "stall current" when you stop them. Avoid stalling motors or running them in near stall in your designs. The currents are extreme and the motors will run very hot. Stall current on the drill motor is 129 Amps or over 1500 watts. Grindage and flakes from ferrous metals are attracted to the magnets inside motors. This is a big concern for open frame motors like the drill and FP motors and fans, where the flakes will jamb between magnet and armature or short out the brush assembly or armature windings. Compressed air will not dislodge these flakes. The speed controllers are not sealed and many have died from metal flakes falling into them. |
#7
I've posted the updated list in the white paper section. If anyone has any other suggestions, let me know and I'll update the document. Feel free to use it as a handout for your team and for new rookie teams. Hope it helps.
| Any Tips on Fundraising? | Zzyzx | Chit-Chat | 3 | 06-10-2004 15:31 |
| White Paper Discuss: Team Regional Perfomance at your finger tips... | CD47-Bot | Extra Discussion | 4 | 14-04-2004 13:56 |
| Where can I learn some mechanical before build season | John JediMaster | General Forum | 7 | 23-09-2003 20:27 |
| Mechanical Engineering | archiver | 2000 | 0 | 24-06-2002 00:04 |
| Max mechanical power of motors, how is it useful? | Ken Leung | Motors | 1 | 09-11-2001 14:15 |
