iframes
In regards to iframes: Why would they be a good thing and why would they be bad? I'd just like to get a general feel for what your opinions on them may be.
Re: iframes
Well,
There is really no "correct" answer to your question. It is true that iframes are not as widely supported by different web browsers, and are more likely to be displayed differently in different browsers, this being the reason why some hate them with passion. Yet, if you test your site is a few major browsers and they appear to display fine, then I see no problem. When used correctly, an iframe can add an extreme amount of functionality to a website that would be hard to achieve through other means. That being said, often I see iframes abused. Personally, I rarely use iframes, however a few weeks ago I was working on a project, and using iframes made the site much more fluid and user friendly. I’m sorry but I really don’t have an example of a good looking iframe vs a bad one. In the end, it all comes down to what you think looks best. Try a site with them, then without and see what the pros and cons of each are. Lastly, I should mention that often search engines do not handle frames well at all, and therefore if it is important that the content inside the iframe is spidered, that factor may influence your decision against them. Sorry I’ve rambled a lot, but I hope this helps you somewhat. Jack Last edited by Jack : 21-10-2004 at 23:00. |
Re: iframes
Heh.
The Robocard's web page uses IFrames. Easy to use and very easy to navigate around with it... http://www.robocards.org I like I-Frames - but older browsers don't like them and if I rember correctly they are not W3C compliant (something of that such) |
Re: iframes
Re: iframes
When this page was implemented it was at a fixed pixel. No resizing, no nothing. If you mess with it you can get it to where everything tries to stay inside the main window it'll all work - but i will admit you are pretty much stuck with the size. It was planned for people with larger resolutions running IE... ![]() |
Re: iframes
The iframe displays wayy down at the bottom, not next to the links where I think it should. Why not keep it at fixed width then? There's no need to make a page resize to the user's browser, plenty of sites don't. Look at yahoo.com or google. |
#7
Re: iframes
The main thing I've found iframes good for is if your server doesn't support server side includes, or if you want to continuously refresh an included page.
For example, on my website, I had a little #include that showed a live stock price. But, it's written directly into the DOM tree, so you can't refresh the #include without refreshing the entire page. Using an iframe can allow you to get around that. The only problem is that you have to make sure you're going to be ok at all resolutions (as was mentioned earlier). MrToast |
#8
Re: iframes
Re: iframes
Let me add in some commentary that should clear a bit of this up and lay to rest a few fallacious notions that I see about frames every once in a while.
Case: the Webmaster has some CGI forum software he wants to integrate into the look of his site. He is either unable or unwilling to delve into the source code to include the forum contents between a header and a footer. Instead, he takes the final output (i.e. website.com/forum/index.cgi, a nice, clean, generated text/html page) and slaps it in an iframe placed within his site layout template. An important advantage to this approach (as Greg Marra sort of pointed out) is that the layout no longer needs to be loaded as someone clicks through links in the forum. Problem solved. Time elapsed: like... five minutes. An aside: if you want to have a static menu and a scrolling content area, do yourself a favour and use includes with CSS to simulate the visual effect. It is this specific usage that makes people hate frames with a passion. Quote:
#10
Re: iframes
I Surf at 1024 * 768 in IE btw. Huge gaps on the sides of a lot of webpages.. It's really annoying. CD stretches and fits my whole page. I like that! |
#11
Re: iframes
Re: iframes
I've only ever come across two sites that use frames in a correct and appealing manner. They are http://www.realgurus.com and http://www.apple-history.com
Personally, I can't stand frames. They seem to be a lazy way of coding a page, and they *rarely* turn out correct. MrToast |
#13
Re: iframes
Re: iframes
Thanks for all the opinions guys. I'm actually doing a project for the Western Michigan Art School. My boss suggested mocking up an iframe layout that would allow us to keep the navigation bars without using a server side include, to speed things up and whatever. I think I'm going to advise we stick to how things are now (except I'm in the middle of a CSS rewrite of the nav bar to get rid of those javascript rollover images). Thanks again for all the advise.
#15
Re: iframes
Back on topic though, I find that iFrames can be either good or bad, but not inbetween. I don't like using them, but there are sites out there that do use them correctly. One site that I personally think does it well is http://www.xjapan.de/main.htm. Another that does it poorly is a few I've made (which is long gone by now). |
