Go to Post The championship event is a meta-game of inches. People will complain about unbalanced/unequal divisions, whether you think it's silly or not. - PayneTrain [more]
Unread 21-10-2004, 18:53
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: How to find the moment of an arm
If it's in a scissor lift configuration, is there a load at the end of the Pipe? If so, that needs to be figured in as well by multipling the load times the distance from the fulcrum. Watch your units and make sure to gear down your motor so that it works at half it's stall torque to maximize its efficiency (except for the FP, Drill, and CIM - check Joe Johnson's / Paul Copioli's motor presentations in the White Papers section).
WHich motor to lift and for arm thoughtful Motors 8 25-02-2004 10:34
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
Correction for arm skyfw Programming 6 06-04-2002 21:59
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
