Go to Post Gracious Professionalism is being embarrassed at an event by an underperforming catstrophe of a robot, yet standing and applauding for every award because you realize that as hard as you worked that season, the other team must have worked even harder to get their achievements. - Taylor [more]
Unread 21-10-2004, 14:51
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
How to find the moment of an arm
Our team is working on a 5 foot arm made out of PVC pipe in a scissor lift configuration. The motor needs to be mounted at the beginning of the 5 feet. We are trying to find out how much weight we need to place behind the arm to counter balance the 5 feet of PVC. The back end needs to be as short as possible. How do we find how much weight we need to mount to the back of the arm?
Matthew
Unread 21-10-2004, 15:43
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: How to find the moment of an arm
assuming uniform weight distribution (of the PVC arm), the moment will be: (weight of arm)*1/2(length of arm)
once you have that, divide it by the distance from the fulcrum to (roughly) the center of gravity of the counter weight. that will give you the amount of weight you need. this doesn't factor in the material supporting the counterweight. if you're concerned about it being slightly off balance because this, you can use the above equation to find the moment of the material supporting the counter balance, subtract it from the moment of the 5 ft PVC arm, and then divide by the distance from the fulcrum to the center of gravity of the counter weight.
final equation:
1/2(distance from fulcrum to end of arm)*(weight of arm)=1/2(distance from fulcrum to end of arm supporting counterwieght)*(weight of arm supporting counterweight)+(distance from fulcrum to CG of counterweight)*(weight of counterweight)
welcome to the wonderful world of statics.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 21-10-2004, 18:53
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
If it's in a scissor lift configuration, is there a load at the end of the Pipe? If so, that needs to be figured in as well by multipling the load times the distance from the fulcrum. Watch your units and make sure to gear down your motor so that it works at half it's stall torque to maximize its efficiency (except for the FP, Drill, and CIM - check Joe Johnson's / Paul Copioli's motor presentations in the White Papers section).
Unread 21-10-2004, 19:11
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
I = 1/3 *M*L^2 if that helps.
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
Unread 22-10-2004, 09:52
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
Thanks. We will get to work on the equations now.
Matthew
Unread 23-10-2004, 16:55
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
not really
and its not stats, its mechanics....
if you can send me a diagram of how it works, i#m afraid i dont know what you mean by scissor lift.....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 26-10-2004, 11:41
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Originally Posted by Denman
not really
No, he really meant statics. Statics is the science of computing forces in things that are not accelerating. It is also useful if you are dealing with motion that is slow enough to be considered static. The essence of Statics is found in the basic equation: the sum of the forces = 0. When you design a bridge you use statics. When you design a slow moving arm, you use statics. When you design a fast moving arm (One where you get a significant amount of "whip") you use Dynamics.
Stats is usually short for Statistics, the science of making sense of large amounts of individually useless data.
BTW a scissors lift is a non-trivial statics problem.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 26-10-2004, 12:20
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Matt,
Am I understanding correctly that you're planning on deploying your scissor lift other than vertically? In my experience, that's a bad idea. You might be able to ameliorate problems if you have some (extreme) precision machining capabilities. But even if you do, you might want to reconsider your design.
Consider that each joint in your mechanism will have some slop in it. This causes sag when the lift is deployed non-vertically. And each stage in your scissor mechanism compounds the sag. If you have very many stages, you will have a LOT of sagging going on out at the end of your arm.
WHich motor to lift and for arm thoughtful Motors 8 25-02-2004 10:34
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
Correction for arm skyfw Programming 6 06-04-2002 21:59
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
