Go to Post If your robot doesn't work, it doesn't matter, because the robot is really meaningless, in the long run. What is the important thing, the reason we're all in FIRST then? To better our understanding of Science and Technology, and hopefully make the world a better place. - Ian W. [more]
Unread 22-10-2004, 21:30
bskll bskll is offline
<What do you think?>
#0820 (Deltatech)
bskll is an unknown quantity at this point
building a robot transport
my team is interested in building a motorized cart that help us transport our heavy robot.
the total amount of weight that the motors has to support is about 130 pounds for the robot and about 20-30 pounds for the cart it self.
we are planning to drive it with a simple drive system of two motors each individually connecting to a chain and then the chain will connect to 1 wheel each.
what gear ratio do you guys suggest? we don't need it to be fast here. we just need to help move along the robot.
thanks for any suggestion.
P.S. this is my first post.
Roger Li
Unread 22-10-2004, 21:46
Waynep Waynep is offline
217 Alum, Former 395/348 Mentor
FRC #1923 (MidKnight Inventors)
Waynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond repute
Re: building a robot transport
Roger,
Congrats on getting onto the Forums. I hope you become a frequent poster. To answer your question on gearing, it really depends on the type of motor you intend to use. So if you send us back what motor you want to use I'm sure we'll be able to provide you with gear ratio selections. Good luck with your cart.
-wayne
395 2TrainRobotics
Regional Champs- '03 VA, '05 PIT, '05 NY, '06 PIT, '06 NY; Regional Finalist- '04 NY; Engineering Inspiration- '03 NY, '06 PIT; Regional Chairman's Award- '04 NY
348 Norwell Robotics
2008 NY Regional Finalist; 2008 Curie Division Champs; 2008 World Championship Finalists
1923 MidKnight Inventors
2009 NJ Regional Champs; 2010 BOS Engineering Inspiration Award; 2011 CT Regional Champs, Gracious Professionalism Award, Coopertition Award
Unread 23-10-2004, 02:15
REVving up for a new season
FRC #2848 (All-sparks)
i agree with wane that we need more information to help you out...please also note that FIRST discourages motorized carts at regionals and nationals. but i would say if you are still going to build one make it as small as possible because that will also have to fit in your pits at regionals.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 23-10-2004, 07:46
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
team 1114 had a motorized cart last year, since we're getting different motors this year i suggest using the old drill motors with the helical gearboxes, i don't think anymore gearing is required after that, just attach the wheels directly to the gearbox, it seemed to work for them
Unread 23-10-2004, 10:47
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Cool we are doing almost the same thing. For my senior project we too are building a motorized cart to carry the robot. Except we are using two wheel chair motors that were donated, we have the motors in a direct drive straight to the wheel chair wheel. Even might use the controls from the wheel chair too.
I have no idea on the correct gear ratio, we almost used the chain drive using an electric car motor, but my teacher brought out a donated motorized wheel chair and that quickly changed our minds.
GOOD LUCK.
Unread 23-10-2004, 11:19
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I would recommend making one as light and simple as possible.
While it is really cool to have one with alot of bell and whistles you should remeber that the more stuff you put on it, the more it weighs and the more it costs to transport is (not to mention the amount of space it takes up).
Think of keeping things more functional than fancy. That goes for the robot as it does the cart.
Unread 23-10-2004, 11:39
[527]phil's Avatar
Alumni
AKA: Phil
and don't forget that if you burn out a motor you'll be carrying the robot, or switching a motor, i think i'll just stick with an old fashioned cart cuz if it aint broke don't fix it, plus we got a load of freshmen to pull it for us , lol
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 23-10-2004, 11:45
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Nonsense, that's the beauty of doing a chain drive, if a motor dies, take out the master link, put the chain somewhere safe, and now you have a slighty heavier push cart, which you can easily make back into a motorized cart should you find another motor.
That being the case, I suggest trying to use a CIM, or something else that will be in next year's KoP, or similar to something in it, because that way if it dies at a competition, you could possibly get replacements from other teams with a bit of trading. Or just use somethin that won't burn out under normal use (like a wheelchair motor, think of the trouble a company could get into for having their wheelchairs dying).
AIM --> Woloi
Email --> ian@woloschin.com
Unread 23-10-2004, 11:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
While motorized carts are really cool, I would not recommend one at all. When you're about to miss a match, a freewheeling cart will get your bot to the field much faster. Also, a non-motorized cart is much afer for everyone else in the pits.
Unread 23-10-2004, 12:55
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
This comes up every year on our team, to build a motorized, super-duper, fancy dancy cart with toolboxes, battery charging stations, etc.. etc... I say keep it simple, light weight, and collapseable if possible. And just how is it getting to the competition - in the same crate as your robot? If the competition is too far to drive it to, are you willing to build a second crate to ship this cart in and pay for the extra drayage and feights charges, hmmm?
Unread 23-10-2004, 13:29
Bcahn836's Avatar
Iraq is fun.
AKA: Brad Cahn
we have always used our cart as a shipping crate for tools, and had it non motorized, but if you remember at Atlanta it was a pretty good distance and always up hill and the same 4 people got stuck pushing it from pits to playing Field, after last year i am tired of pushing that cart, so we are building a motorized on that will work like a lawn mower with a power assist. And we will still be able to use the cart as a shipping crate with tools we would just have to un hook the motors and unbolt the casters in front and board up the sides. Oh and it is only 10" bigger than the cart we used last year that fit in the pits just fine.
Unread 23-10-2004, 13:52
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
That cart was my little baby. It was an offseason project to determine weather a CVT was viable. As it turns out it was. It used 1 drill motor with the planetary gearbox, and a set of variable diameter pulleys from www.hi-lo.com
They worked by having 2 pulleys that expand and contract. One is spring loaded, while the other one has a handwheel that turns to vary the pulleys diameter.
It worked out quite well for our application, and achieved a speed of 2tf/s in the low end of the CVT and about 8ft/s at the high end. I also played around with the sprocket ratios on the wheel to make it go faster for racing around the halls at school.
I don't think the variable diameter pully system is the way to go for FIRST robots. the system is
1. bulky
2. heavier than many 2-speed designs
3. harder to control than a 2-speed, since you need to have a motor and a potentiometer to change the gear ratios. For our application, we just turned the knob on the bottom manually.
4. Although we never experienced any slippage in the pulleys, the chance exists under high loads.
All in all, building a cart can be a good offseason project, and can be a good test platform for new designs. Or you can just put a sound system in and make it look cool, either way, carts are cool.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 23-10-2004, 15:01
IndianChieftain's Avatar
IndianChieftain IndianChieftain is offline
FRC #1241 (Theory 6)
IndianChieftain is on a distinguished road
if the reason anyone is building a motorized cart is so that it stands out, then there are lots more ways to build one. for example you can put a boom box on the cart and power it with a 12 volt battery. or police lights. those will certainly make the robot and the team stand out
04-05-Regional Champions - Waterloo (Thanx 1305 and 68)
04-05-Team Spirit Award - Waterloo
04-05-Entreprenuership Award - Waterloo
03-04-Rookie All-Star award - Great Lakes Regional
03-04-Rookie Highest Seed - Greater Toronto Regional
03-04-Rookie All-Star award - Greater Toronto Regional
03-04-Damier Chrysler Team Spirit award - Greater Toronto Regional
03-04-Damier Chrysler Team Spirit award - National Championships
Unread 23-10-2004, 18:16
[527]phil's Avatar
Alumni
AKA: Phil
hmm how bout a disco ball, strobe lights, and a dj, that'll make a cool cart for the pits, lol, i think evryone should keep it simple, the competition is about the robots, not the carts, you can have the greatest looking most complicated cart, but if your bot sucks it really doesn't matter.
Unread 23-10-2004, 23:21
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I think that your weight estimate is low. With space in the pit at a premium, we use our cart as a work table too. That means we hammer and bang on it, as well as moving arms around with puts other pressures on it. Tools also can get carried on it, and are nice to have at the field, or sometimes necessary as the robot is worked on en route to the field, or during the elimination rounds if you are so lucky. Also, it only weighs about 30 lbs and comes apart to fit into the crate for shipping with the robot.
Not to discourage you from building a motorized cart, but I think that you are way low on your load estimate.
Wetzel
what kind of robot will win? Bcahn836 Championship Event 44 12-04-2004 00:02
Building more than one robot / expanding the "season" Mr. Van General Forum 25 19-02-2004 17:51
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Time spent building robot jdawson General Forum 12 25-02-2002 17:53
