Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 25-10-2004, 16:42
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Re: iframes
Originally Posted by Raven_Writer
One site that I personally think does it well is http://www.xjapan.de/main.htm. Another that does it poorly is a few I've made (which is long gone by now).
There are two reasons why that site uses iFrames correctly:
1. The menu on the left doesn't extend beyond the bottom of the page (at least not in my browser)
2. The frames don't have those wicked annoying borders. Borders = bad. They disrupt the flow of the page.
MrToast
http://www.davedelong.com/daveware <<--- can you find the iframe?
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 25-10-2004, 17:14
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: iframes
Originally Posted by iBob
Thanks for all the opinions guys. I'm actually doing a project for the Western Michigan Art School. My boss suggested mocking up an iframe layout that would allow us to keep the navigation bars without using a server side include, to speed things up and whatever. I think I'm going to advise we stick to how things are now (except I'm in the middle of a CSS rewrite of the nav bar to get rid of those javascript rollover images). Thanks again for all the advise.
If your webserver allows SSI includes or supports PHP (and thus PHP includes) I highly recommend using them. I have done several websites with includes (http://www.southwindsorswimclub.com for one), and found them very useful in quickly editing content while providing a nice enclosing feel to the site. A header.html and a footer.html are easily included and open and close my content area, so each page only need to be the content that actually goes in that page. It makes things much easier to track and edit, IMHO.
There's a problem with viewing the site in FireFox. I'm currently trying to figure out what is causing the problem.
Two ideas. Try adding style="float: right" to the iframe tag, or extend the table that does your navbar with another td with rowspan=8 and that way it will -always- be inline with the navbar. Just make sure to set heights and widths appropriately. Oh, also you might be using percents for widths, and the percents could round off in such a way in FF that the iframe is just too big to fit next to the navbar, and so its inserting a linebreak to get it down. Try reducing it's width slightly too.
Unread 25-10-2004, 19:28
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: iframes
Can YOU find the iframe? http://www.team188.com/web/index.php...agetitle=Forum
Unread 25-10-2004, 19:44
Re: iframes
Originally Posted by jonathan lall
That's not an iframe per se. But nice CSS in that page.
Unread 25-10-2004, 21:50
Re: iframes
Yeah, a certain property of the iframe element doesn't allow me to do what I wanted to do (basically make it seamless, by enclosing it in a smaller box), so I made the "iframe" an object (type="text/html") to get around that while maintaining complete validity and semantic soundness; this trick works in all browsers I've tested, as it should if you read the XHTML and HTML 4.0 specs... but I was hoping you guys wouldn't figure it out so fast.
Unread 13-11-2004, 22:31
XYR0c XYR0c is offline
How will it end?
AKA: ClaytonShannon
#1288 (R.A.V.E.N. Robotics)
Team Role: Communications
XYR0c is on a distinguished road
Send a message via AIM to XYR0c Send a message via MSN to XYR0c Send a message via Yahoo to XYR0c
Re: iframes
The team web page that I designed uses an iframe. I don't know whether its a 'good example of iframe useage', or an 'example of bad iframe useage'. Nevertheless, i believe they can enhance a site that uses a lot of interface and interface images that would have to load each time the client navigates to a link. I have tested my site on many browsers and they all seem to display the iframe fine, except for Fire Fox, which moves it 1 pixel to the right, UH OH. lol.
Unread 14-11-2004, 17:09
Re: iframes
Sometimes there are 'hacks' that you can use to trick certain browsers into displaying things certain ways, but I don't really advise doing it to fix a small problem.
Most web browsers 'cache' images so that if they're called again or you revisit the page later it doesn't need to redownload them. Besides, your navigation images (in fact, any image used as part of the layout) shouldn't be large. Unless you're doing some sort of really graphic stuff, a GIF or PNG file ought to be able to get you better compression.
Unread 14-11-2004, 22:38
dragonpaulz's Avatar
dragonpaulz dragonpaulz is offline
4 P3r$0n
AKA: Paul Shapiro
#0555 (Team 555)
dragonpaulz is an unknown quantity at this point
Send a message via AIM to dragonpaulz
Re: iframes
If you have PHP, what you should do is make a php include and add a CSS overflow.
Overflow Tutorials:
http://www.domedia.org/oveklykken/css-div-scroll.php
http://webdesign.templatemonster.com...flow.2324.html
http://www.topxml.com/css/css_property_overflow.asp
http://www.beforethedog.com/tutoriali/tut1.htm
PHP Include Tutorials:
http://www.entensity.net/tutorials/p...av/easynav.htm
http://www.netcode.net/tutorials/php/includes.php
http://www.netcode.net/code/php/show...on_Replacement
http://www.netcode.net/code/php/show...h_Replacement2
http://www.purephotoshop.com/article/55
Team 555 - Montclair High School
Trust, Love, and Magic
WebMaster of MontclairRobotics.org
