Go to Post I've come to believe that the current alliance selection system is just like democracy. It's the worst system possible, aside from all the other ones. - DampRobot [more]
Unread 28-10-2004, 17:56
stevex stevex is offline
AKA: Steve
#0219 (Team Impact)
Team Role: Electrical
stevex is an unknown quantity at this point
Send a message via AIM to stevex
PWM Signals
Hopefully I got this right, but I can only program PWM signals 13-16 correct? I can't program 1-12 to do a function I desire?
Unread 28-10-2004, 18:03
Umm Errr...
Re: PWM Signals
If by program you mean contol then you can control all of them. PWMs can only be updated as often as you call Putdata(). 13-16 can be configured so that you can update them as often as you like. There is more info on this in the manual. If you still have questions i will see if i can help
1139 Alumni
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
Fading LEDs using a PWM signal from the Edubot DanL Programming 22 30-03-2004 00:07
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
