Go to Post To think that one can "learn" engineering in 6 weeks while under the strain of building a robot too is proposterous. FIRST isn't about teaching. It's about inspiring. - Collin Fultz [more]
View Poll Results: What sensors do you typically use on your robot?
limit switch/touch sensors 38 79.17%
optical sensor 33 68.75%
IR or SONAR Rangefinder 5 10.42%
angular accelerometer 9 18.75%
linear accelerometer 1 2.08%
encoders 25 52.08%
potentiometers 29 60.42%
current transducers 7 14.58%
pressure transducers(pneumatic or otherwise) 11 22.92%
compass 1 2.08%
Other (i'm sure someone will find somehtign i didn't list) 6 12.50%
Multiple Choice Poll. Voters: 48. You may not vote on this poll
Unread 28-10-2004, 19:08
Umm Errr...
Re: POLL: What sensors do you use
Come on now ppl. 15 ppl have voted but only one has bothered to post anything. Give some descriptions.
1139 Alumni
Unread 28-10-2004, 20:03
Lindsey Lindsey is offline
Lindsey will become famous soon enough
Here’s the rundown on what we used and what for.
In 2003 we had:
- tilt sensor (to detect when we were on the ramp and help prevent us from tipping)
- limit switch (to keep the arms from closing beyond mechanical stops, prevent stalling the motor)
- gyro (to turn a specific angle to go to the ramp, auto mode)
- optical sensors (3 to detect when the robot crossed the line, auto mode)
In 2004 we had:
- current sensors (mainly for decoration we hooked up colored bar-graph readouts)
- pressure transducers (2? to make sure our center pivot wheels, mounted on pneumatics, were all the way down)
- optical sensors (to detect when the robot crossed the line, auto mode)
- gear tooth sensors (they count gear teeth & we used them to count wheel revolutions, auto mode)
Both years we had custom circuitry to help with the sensors.
I thinks that’s about it.
Lindsey
Unread 25-11-2004, 21:34
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Team 1425's Robot (2004)
-2 limit switches on the top and bottom of our chain slider, so the chain wouldn't go too far and break the turnbuckles (it did it twice before we put them in.)
-2 more limit switches set up to bounce on a hex bolt, to act as encoders (tacky, yes, but we didn't have time for anything else.)
-1 potentiometer, used for the sole purpose of changing programming variables on the fly.
-1 standard switch, used for turning Autonomous mode from left to right to
off.
-1 pressure transducer, to detect when we could use all 60 psi to lift.
-(almost) 2 current sensors, but they were being stupid.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 26-11-2004, 07:17
We use microswitches for position and limit detection. Pots for rotating position info. (Pots were used on our arms and are an essential part of our crab driving modules. They are used in closed loop servos) Let us not forget that pots are an integral part of the supplied servos. We started using current sensing several years ago and it was a real eye opener when compared to match play and battery terminal voltage. We have used the gyro in auto mode to help run straight and get to a final position. We experiimented with the IR transducers but found that there was faster ways to get to the side goals this year.
Unread 27-11-2004, 12:04
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Cool Mostly Banner Sensors and a microswitch or two
In 2004 we were fortunate to finally add a programming mentor and could do more than run the default program. We used an array of four optical sensor for line following and a seperate sensor for proximity to the wall. We also used some limit switches to stop rotation on our biggens ball arm. We had the pressure transducer on the compressor in hopes of cycling it but issues with autonomous occupied the ten weeks until regionals.
I am very much looking forward to this season as we have added a second programming mentor and an electronics mentor.
Question1: Is the gyro chip still legal? I seem to recall that it wasn't included in the kop last season but I am fuzzy in regards to whether it could be one of the off the shelf electronics purchases.
Question2: I am researching encoders and would appretiate any reference data for sensor that you have used and liked. Part #, online catalog, ...
Thanks ,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 27-11-2004, 12:54
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Limit switches are a must for any mechanical device driven by a motor. Hard stops are necessary too, but without a limit switch to tell the RC when the device has reached it's end, the motor will continue to drive the device, even after it's hit the hard stop. Every motor-driven mechanical function I've ever worked on has always had limit switches in every critical place.
We have often used pots to determine the angular location of an arm or device, and I think team 25's arm this past season is the best example of a creative use for pots I've ever seen.
Optical sensors/banner sensors are one of the easiest methods of counting traveled distance accross the field. Paint gray/white/silver wheel hubs with a black matte paint at equal increments, and you've got a decent/cheap/easy counter.
In 2001 we used the gyro/angular accelerometer to self balance on the ramp carrying two goals (in under 30 seconds ).
Unread 27-11-2004, 20:48
vtrehan's Avatar
vtrehan vtrehan is offline
Mentor - Controls & Programming
AKA: Vivek Trehan
FRC #1241 (Theory6)
vtrehan is on a distinguished road
Send a message via Yahoo to vtrehan
We didn’t have many sensors last year as we were well.... rookies .
This year we are planning to work with an IR sensor mounted on the wheels for distance calculation (and we have a working prototype), and we used opto sensors for line following, we also had some limit switches for various purposes.
We are actually shopping around these days for a more reliable sensor for distance calculation, so if someone can recommend something more reliable and simple, please let us know .
Thanks,
Vivek.
2006-GM Industrial Design Award - Greater Toronto Super Regional
2006-Engineering Inspiration Award - Arizona Regional
2006-Regional Finalist - Arizona Regional
2005-Best Defensive Robot - Wonderland Off-Season
2005-Regional Chairman's Winners - Greater Toronto Regional
2005-Regional Champions - Waterloo (Thanks 68 and 1305)
2005-Best Website - Greater Toronto Regional
2005-Team Spirit Award - Waterloo
2005-Entreprenuership Award - Waterloo
2004-Rookie All-Star award - Great Lakes Regional
2004-Rookie Highest Seed - Greater Toronto Regional
2004-Rookie All-Star award - Greater Toronto Regional
2004-Team Spirit award - Greater Toronto Regional
2004-Team Spirit award - National Championship
Unread 28-11-2004, 00:07
Umm Errr...
Thanks,
Vivek.
In a word words: encoders. Search the forums and you will find several detailed threads. They are very easy to use and extremely accurate
1139 Alumni
Unread 28-11-2004, 14:46
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I coded for (Whether or not they were placed on the bot, but most were) numerous sensors.
  • 3 pots (shoulder, arm, & hand position)
  • 1 switch (arm limit)
  • 4 banners (quadrature)
  • 1 current (for the hand, made a overload mech around that)
  • 1 pressure (the simple pnuematic one, only controlled the compressor)
  • 1 Gyro (compass)
I think that's it.
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
idea: a semi-official coaches poll archiver 1999 8 23-06-2002 22:23
