Re: Is a shifting transmission really necessary?
well as for breaking apart... most of the times if the shifter is messed up or something you can just lock it in one stage... and then its basically just a heavy dual motor drive system.... i can't really think of much more going wrong with a shifting tranny ... now a planetary drive .... yes
Hi!
the only competition I have seen was the '04 competiton, where I co-piloted for our team, 1425. We did not shift. We did not have time to put together a tranny, but our team leader would have really been tickled if we could. I personally didn't see a reason for a transmission. In the '03 competiton, I could see why speed was required (a lot of space, a race to get to the top, ect.) but in the '04 competiton, I didn't see a reason, because there wasn't much room to get up to speed, and there wasn't anything that could have been taken back with some shoving. (not a FIRST-encouraged manuver, but these things happen.) I totally agree that it depends entirely on the competiton and what you are doing. Like I said, I am a rookie, so my test pool is minute, but I think generalizing about whether or not you need a transmission won't get you anywhere. Sparks |
Our teacher put it this way. Their is always an advantage to shifting. But is expending the extra resources to build it worth the advantage?
This is, in fact, the main reason for a low gear in a transmission. |
Design for how you plan to play the game. If you need two or more clearly definable speed regimes, then shift. If not, then don't. ChrisH |
| Slickest drive transmission yet... | dlavery | Technical Discussion | 58 | 10-01-2005 19:33 |
| The perfect 2 speed Transmission..... features... | Salik Syed | Technical Discussion | 28 | 20-10-2004 11:44 |
| Need info on gears inside drill transmission. | sanddrag | Motors | 7 | 14-04-2004 11:01 |
| 3 shifting transmission... | Arefin Bari | Technical Discussion | 19 | 04-03-2004 01:24 |
| 322 Three speed transmission. | dkeith | Robot Showcase | 8 | 10-06-2002 22:33 |
