Go to Post Common sense can take you a long way!!! - ClintDog [more]
Unread 29-10-2004, 14:00
ufa_mike ufa_mike is offline
AKA: Mike Deaves
#0865 (Warp 7)
ufa_mike has a little shameless behaviour in the past
Converting Cad Files
Does anyone know of any file converters that will change an inventor file (.ipt)
to a mastercam 8 file (.mc8). I need this because the place I work is willing to let us use their CNC mill to cut some gearbox pieces, but their machines use mastercam and we only have inventor.
I've heard that there are programs to do it but I have yet to find one.
Thanks
" I once played poker with Tarot cards; I hit a full house and four people died."
Unread 29-10-2004, 15:29
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Re: Converting Cad Files
This came from the Master Cam Website
"Built-in data translators for IGES,
Parasolid®, SAT (ACIS solids),
AutoCAD® (DXFTM, DWG, and
InventorTM files), SolidWorks®, Solid
Edge®, CADL, STL, VDA, and ASCII.
Direct translators for STEP, Catia®,
and Pro-E® are also available."
So it looks like you don't need to but you may want to try it first. You also have the option of saving it as a different file format like IGES. Most cam software will read that.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 29-10-2004, 16:32
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I always used to do this by exporting the model from Inventor as a .SAT file then importing the .SAT file in Mastercam.
If you look around in the programs you should be able to figure out how to inport and export (file->export and open->input are common menu selections).
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 29-10-2004, 17:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I hope you understand that A CNC machine does not make parts from models. It needs a complex program made up of G codes. What Mastercam does, is allow you to draw toolpaths such that will create the part you imported. Then it can automatically generate the G code. Inventor is purely a CAD program, not CAM. To run your part on a CNC, you will need mastercam or just program it manually.
Unread 29-10-2004, 17:51
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
MasterCam 9.1 SP2 has a converter that supports Inventor ipt files. While I'm stll learning MasterCam, so far it has converted them fine. Setting up the toolpaths and Job Setup is really where MasterCam's strengths lie. Having the right PostProcessor is essential as well. This can be tricky, as you may need to contact the company that made your CNC or write your own Post.
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
Converting CAD!? Tton 3D Animation and Competition 3 25-03-2003 17:29
Converting Files Hailfire Programming 9 28-12-2002 18:59
Bosch Drill Motor CAD Files Madison Inventor 10 09-12-2001 00:14
