Go to Post 99.9999% of the FIRSTers are really nice - Denman [more]
Unread 30-10-2004, 11:46
FRC #0701 (RoboVikes)
Re: Is a shifting transmission really necessary?
well as for breaking apart... most of the times if the shifter is messed up or something you can just lock it in one stage... and then its basically just a heavy dual motor drive system.... i can't really think of much more going wrong with a shifting tranny ... now a planetary drive .... yes
Team 701
Unread 25-11-2004, 21:26
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Hi!
the only competition I have seen was the '04 competiton, where I co-piloted for our team, 1425. We did not shift. We did not have time to put together a tranny, but our team leader would have really been tickled if we could. I personally didn't see a reason for a transmission. In the '03 competiton, I could see why speed was required (a lot of space, a race to get to the top, ect.) but in the '04 competiton, I didn't see a reason, because there wasn't much room to get up to speed, and there wasn't anything that could have been taken back with some shoving. (not a FIRST-encouraged manuver, but these things happen.) I totally agree that it depends entirely on the competiton and what you are doing. Like I said, I am a rookie, so my test pool is minute, but I think generalizing about whether or not you need a transmission won't get you anywhere.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 25-11-2004, 21:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Our teacher put it this way. Their is always an advantage to shifting. But is expending the extra resources to build it worth the advantage?
Unread 26-11-2004, 09:23
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Sparks
The rules specifically indicate that pushing [shoving] is OK and expected. Why would you say it's not FIRST-encouraged?
This is, in fact, the main reason for a low gear in a transmission.
Unread 29-11-2004, 10:58
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Actually, last year we used our low gear for climbing so that we could avoid all the pushing and shoving. But with the dynamics of last year's game we felt that anybody who got into a shoving match, was probably doing the wrong thing. The 02 and 03 games were a different story. There was a lot of space to cover and you had to be able to hold your ground when needed.
Design for how you plan to play the game. If you need two or more clearly definable speed regimes, then shift. If not, then don't.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
