Go to Post If there's one thing that I love, it's a good scouting challenge! - wilhitern1 [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 30-10-2004, 22:52
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
New Dublin Robotics (1014) Site
Over the summer and early fall we have developed the new version of our website. We are still working on adding content and other features for our team to use. I know the design doesn't fit 800x600 perfectly so I still need to do a little tweaking with and and any suggestions from you guys are always welcome.
www.dublinrobotics.com or www.badrobots.com
The badrobots URL is in reference to our t-shirts this past season, which had a robot picking up a stick figure and placing him in a movable goal with "BAD ROBOT!" written under it. We hope to continue this basic shirt theme idea, so we registered a domain accordingly.
Unread 31-10-2004, 00:35
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Re: New Dublin Robotics (1014) Site
Very nice. I have no complaints.
MrToast
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 31-10-2004, 01:32
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Let me start off with: your site is awesome. I love the rollover images on the menu. I like your graphic. The site seems really well laid out. OK, now to the critiquing, the links up in the top are repetitive, your menu system is not the complex that you need to display the most prominent links up top. You have a navigation bar on the top left, I like that, but I've noticed it only goes one layer in. I'd suggest that you follow it all the way in, for example: "Home - About Us - Bad Robot?" instead of just "Home - About Us". Don't stress about it, only do it if you can make sometime of PHP loop that is capable of generating the path for every page. I wouldn't suggest manually coding up every single page. Your search up in the top right isn't really clear that it is a search, I'd suggest a search button much like Chief Delphi's. A search button that yields a search field when clicked on, and an option for advanced search. Lastly, I'd try to make the FIRST logo a link to http://www.usfirst.org/. Other than those minor things, the 800x600 issue and a minor lack of content at the moment, it's an awesome site.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 31-10-2004, 01:47
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Badass. The only two things from a stylistic perspetive I would take issue with are the aformentioned repetitive menu links (which look good but are a little silly when you think about it) and the fact that there is no cool graphic/focal point on the front page; there's only news. These of course are completely subjective, and everyone will have a differing opinion about them. Perhaps also the fact that there is no active or hover property for buttons could use tweaking, but that's an even smaller issue. As you said, the fact that it doesn't work in 800 x 600 is quite a large problem, and might be a tad harder to fix with tables (strange that you use them for a fixed-width site), but it shouldn't prove a problem, considering you were able to make such a good site.
Unread 31-10-2004, 13:26
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
AWESOME site, but I have one suggestion...You need to make the background a little bit more colorful but don't over-do it with color...
-Kyle
Overall a great site the way it is though.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 31-10-2004, 15:55
Eric Rowe
Now that it's mentioned, the background does seem lacking. I wouldn't put color in it though, I'd make it a gray to match the rest of the site, keep the gray lighter, but not strict white. You might want to make a little background image that is not distracting, yet keeps the eye occupied, even if it is in just the open space.
Eric Rowe | Alumn
Unread 05-11-2004, 22:23
AKA: Kevin Dieterle
I've made most (if not all) of the changes suggested here, including 800x600 compatibility, and I think the result turned out fairly nice. If you have any new opinions based on what I changed, just let me know.
Jonathon - I added a little bit of a focus point at the top of the first page, but I feel that it still needs a little something. Any suggestions?
Unread 05-11-2004, 23:33
PCole's Avatar
PCole PCole is offline
Media / Website Mentor
AKA: Patrick
FRC #0384 (Sparky384)
PCole will become famous soon enough
Send a message via AIM to PCole
Very well done.. I like the rollover effects.. good choice of colors.. looks nice.
One suggestion, at the bottom, maybe make an image for the shadow to finish at the bottom instead of just cutting off.
Unread 06-11-2004, 01:17
Eric Rowe
Looks very nice, but on certain pages, I get rendering problems in using Firefox 1.0 RC2. One page for example: http://www.dublinrobotics.com/index....13&Itemi d=41. It looks fine for a couple seconds, but then the copyright info jumps to the top left, and the white background disappears leaving the gray. The happens consistently on my computer, but someone check to make sure this problem is universal. Other than that, the changes are all for the better.
Eric Rowe | Alumn
Unread 06-11-2004, 01:26
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Nice site overall, but not that user friendly with my resolution of 1024 x 768.
The text is very small. But, don't worry about it. I am used to websites not being up to par (i guess) when it comes to my preferred resolution.
BTW, any chance of trading shirts this year?? I love that Bad Robot concept, and would like a shirt from your team.
PM me if you are interested in trading.
Unread 06-11-2004, 10:48
AKA: Kevin Dieterle
I've noticed that a few times using 1.0PR, but I haven't been able to reproduce it. I made a few changes to the CSS just now and I haven't seen it happen since, but if you still get the rendering issue, let me know.
Unread 17-02-2005, 03:47
karch karch is offline
In Zip Tie Heaven
AKA: Brian Liu
FRC #1510 (Westview Robotics)
karch is on a distinguished road
Send a message via AIM to karch
preload your mouseover images and swap - don't force your user to redownload the images over and over again. it's distracting on the status bar, and it's not smooth.
other than that, it's cool.
one personal pet peeve, though... i've never been a big fan of the effect you used on dublinrobotics. but, that's just me.
Robotics and the Meaning of Life Andrew Rudolph Chit-Chat 4 23-07-2004 19:38
The Hunger Site Jeff_Rice Chit-Chat 3 25-04-2004 17:55
Finney robotics team a winner Joe Ross FIRST In the News... 11 09-04-2004 23:02
**FIRST EMAIL**/First Annual FIRST Robotics Conference, April 16 April 18, 2004 for t miketwalker FIRST E-Mail Blast Archive 6 04-04-2004 18:31
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
