Go to Post Let's sheathe the pitchforks and douse the torches for another two months, shall we? - Taylor [more]
Unread 02-11-2004, 16:25
cibressus53's Avatar
cibressus53 cibressus53 is offline
cibressus53 is on a distinguished road
Simplest Code
What is the simplest code we can upload to the robot? I'm quite pressed for memory space. i can't get both the default code and cordic math libary on their
EMAIL: TERRYnospamP AHT MELDSTARspammenot DAWT COM
Unread 02-11-2004, 17:39
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: Simplest Code
I believe the simplest code you can download to the robot and have it do something is the default code.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 02-11-2004, 17:50
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Simplest Code
What does "the simplest code" mean? If you just want some joysticks and buttons directly mapped to pwms/relays and don't have any autonomous code, there is a significant amount you can remove from the default code. There are several functions you can remove from user_routines.c/h. Removing printf_lib.c/h and any calls to it would be another very significant space saver. There is probably more in other files, look for yourself.
Team 1257
Unread 02-11-2004, 18:30
Re: Simplest Code
well, after adding the cordic libary to the base code, it sweels to 48kb.
Unread 02-11-2004, 20:18
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Simplest Code
Can someone speak up who has actually used CORDIC on the IFI robot controller?
My thought is that the CORDIC implementation you're using is no good for our application. I'm wondering if the one you're using uses floating point math. If it does, that would swell the code due to the fact that the math library would have to emulate the floating point operations in software.
Unread 02-11-2004, 20:31
Bharat Nain's Avatar
Re: Simplest Code
Why do you want to add the CORDIC library to your base code anyways?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 02-11-2004, 21:52
Re: Simplest Code
I did some experimentation with it early on, before we gave up on our optical carpet tracking scheme.
CORDIC was devised specifically to avoid floating point operations. It uses addition, subtraction, and bitwise shifts. Doing those with floating point would be, um, pointless.
Unread 02-11-2004, 22:39
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Simplest Code
After some experimentation, it appears that the size of the hex file does not directly correspond to the amount of code that is actually uploaded to the robot controller. The hex file containing the default code has a size of 25 KB, while the hex file with the CORDIC library included (I believe this is the library in question) has a size of 48 KB. Even though this hex file is larger than the PIC's 32 KB flash memory, it still uploads and executes on my RC without any problem.
So it seems therefore the size of the hex file containing the code is not an accurate measure of how much flash space the code will take up on the RC.
cibressus53, I think your problem lies somewhere else than in the size of your code.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 02-11-2004, 23:22
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Re: Simplest Code
Originally Posted by Pat Fairbank
...the hex file with the CORDIC library included... has a size of 48 KB. Even though this hex file is larger than the PIC's 32 KB flash memory, it still uploads and executes on my RC without any problem.
Pat,
In the most general case, a hex file will be more than twice as big as the memory image it loads. This is because each byte of the memory image gets represented by two ascii characters in the hex file. And then there is the overhead of having to store address information, CRC/checksum information, and who knows what else.
Unread 05-11-2004, 09:28
Re: Simplest Code
I had to completly remove the print_lib to get it down to a small enoguh size (35kb). does anyone know the real max size for the hex file?
Unread 05-11-2004, 11:46
Re: Simplest Code
You can't easily judge by the .hex file size. I can create a .hex file that's 85kb and it fits on the RC just fine.
You know what it does look like though is an IFI_Loader version problem. The original IFI_Loader had a bug that only loaded half the available RC program memory. Check your IFI_Loader version. It should be 1.0.7.
You should use the .map file MPLAB can generate for you to see how much memory your program requires. It tells you exactly how much space your program uses, e.g.,
Program Memory Usage
Start		 End
0x000800	0x000805
0x000808	0x006622
0x300000	0x30000d
24111 out of 33816 program addresses used, program memory utilization is 71%
Note however that the program memory will be full when it reads 90%, because that last little bit of memory gets used for IFI stuff.
Unread 05-11-2004, 12:01
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Re: Simplest Code
Good catch. I had forgotten about that. This version is available from Innovation First at http://www.innovationfirst.com/FIRST...ader_1.0.7.zip. I hope that solves the problem for you.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
