Re: RadioShack-IFI Collaboration Proof?
I also worked with the BOE bot when I was in high school about 3 years ago for almost 2 years straight, yes they are two ( 2) modified servos. There is a lot you can learn with it and figure out to do. It used code similar to the controllers before the black IFI controllers so it was a learning experience for me for FIRST. I believe I have both of the BOE bots which we used and if I could find the second one which my partner used I would be willing to part with it for a cost, much less than new as its a little old and used but still good. PM me or something to ask about it.
I remember the BOE-Bot's...I remember the hours spent creating things with them that would terrorize spangler(my CIM teacher) (mike you know what I mean). We used them in our CIM class to practice with plc's. Very good kit, and highly recommended..and if you ever get bored of the stock chassis, or what not, its simple to create you own for a custom application, with a plc and a few relays, you could power bigger motors and other large current drawing devices, and you could even make from parts bought at radio shack simple H-bridge motor controllers, or take the time to make a variable speed motor controller. its easier than you think to make a motor controller that reads the pwm signal, and can run a high power motor. Just an example of how you might expand upon the kit to do other fun things.
AS others have said, the BOE-Bot is not Robovation. The main difference is that the chassis is only the single piece of metal you see there -- there are no additional structural parts included.
For more information on what comes in the kit, see http://www.parallax.com/detail.asp?product_id=28132 Last edited by ahecht : 03-11-2004 at 11:40. |
| [moderated] Collaboration | Brandon Martus | General Forum | 43 | 21-03-2004 20:51 |
| IFI Loader usually hangs midway thru load | gnormhurst | Programming | 4 | 04-02-2004 11:40 |
| IFI Loader Problems | BrendaB | Programming | 3 | 24-01-2004 22:45 |
| Bug in IFI Loader | rwaliany | Programming | 2 | 06-01-2004 21:26 |
