Go to Post I'm basically only posting this so that future Shaker Robotics kids will see it and tell themselves "never again"... - Chris is me [more]
Unread 03-11-2004, 15:55
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: How do you drive the KOP 6" wheels?
In the past we have used a hub (found on www.firstcadlibrary.com under mechanical) with a sprocket attached to it. You will probably need wheel wedges also (found on www.firstcadlibrary.com under manufactured). Last year we attached a gear to an aluminum adaptor to the hub to drive our tri-wheels. You may want to machine the hub's yourself out of Delron because we found the "MMH" version to be too weak. They broke apart quite eaily because they are molded.
If you need some more 6" wheels for your idea let me know. We have a bunch here. Good luck with your 6 wheel drive, I can't wait to see it run. If you need any help let me know.
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Need 6" wheelchair wheels! archiver 2001 5 24-06-2002 03:08
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Rumor or no--- WPI has 12 drive wheels?!?!?! archiver 2001 12 23-06-2002 23:22
