Re: How do you drive the KOP 6" wheels?
did you mean delrin? if not id like to know what delron is and what do the wheel wedges do?? |
It seems to me that the wheel wedges do the same thing as the wheel hub on firstcadlibrary.com but the hub includes an extra 1/4" - 1/2" plate to mount things to.
The wedges (and the cutouts on the hub) fit in the spaces between the "spokes" on the wheel. All it does is make a flat surface to mount the wheel to a base or, a sprocket. See picture here. This one uses the wheel hub (with the sprocket on the opposite side mounted on the open part of the hub). Open part of the hub meaning the side without the flat surface. In this case, the flat surface sits flush to the spoke and the sprocket is mounted on the opposite side. http://www.team237.com/gallery/6-Wee...-Time/MVC_048F |
and heres the sprocket = http://www.team237.com/gallery/6-Wee...-Time/MVC_056F, http://www.team237.com/gallery/6-Wee...-Time/MVC_024F Last edited by Alex Cormier : 03-11-2004 at 16:28. |
On SwampThing we used .5" shaft with the 6" wheels we turned delrin adapters for them and used spring pins. However in finals at UCF a pin sheared and Pretty much crippled it for a match. had it not failed we would have won that match and possibly the regional. The problem was fixed on the fly By James Jones of 180 by drilling a hole through it all and then using the drill bit he drilled it with it to hammer into the hole he made as a codder pin. As for the 6" wheels they are excellent wheels especially after they have been used for a while then they have a flat tread and are in their prime. they aren't very great for traction but that is perfect for 4 wheel drive. we were second seed at UCF and undefeated Winners of the Robot rodeo.
Last edited by Tytus Gerrish : 03-11-2004 at 16:46. Reason: Gosh My spelling sucks |
We also added a little something to the tread of the wheels to help them stick. We turned the rubber down to a flat surface and put on a little traction. Something we had left over from our 2003 wheels. It worked great. We didn't spend much time on the carpet so turning wasn't an issue. When we did test the traction on the carpet she didn't turn as easy as our past 4 wheel robots. And PB any time you want to stop by & check out our robot or "supplies" you are more than welcome. You must know how the Rochester teams are always willing to share with each other. |
| Globe gear box | Pat Roche | Motors | 9 | 25-05-2004 22:50 |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Need 6" wheelchair wheels! | archiver | 2001 | 5 | 24-06-2002 03:08 |
| Lots of Wheels and F = u x N | archiver | 2001 | 17 | 23-06-2002 23:37 |
| Rumor or no--- WPI has 12 drive wheels?!?!?! | archiver | 2001 | 12 | 23-06-2002 23:22 |
