Go to Post There's a stark difference between bragging and taking pride in your work. While "Ha ha! We're better than you! We won seventeen regionals and you didn't!" would clearly fall in the former, listing your achievements would definitely fall in the latter. - artdutra04 [more]
Unread 03-11-2004, 16:40
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: How do you drive the KOP 6" wheels?
On SwampThing we used .5" shaft with the 6" wheels we turned delrin adapters for them and used spring pins. However in finals at UCF a pin sheared and Pretty much crippled it for a match. had it not failed we would have won that match and possibly the regional. The problem was fixed on the fly By James Jones of 180 by drilling a hole through it all and then using the drill bit he drilled it with it to hammer into the hole he made as a codder pin. As for the 6" wheels they are excellent wheels especially after they have been used for a while then they have a flat tread and are in their prime. they aren't very great for traction but that is perfect for 4 wheel drive. we were second seed at UCF and undefeated Winners of the Robot rodeo.
Last edited by Tytus Gerrish : 03-11-2004 at 16:46. Reason: Gosh My spelling sucks
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Need 6" wheelchair wheels! archiver 2001 5 24-06-2002 03:08
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Rumor or no--- WPI has 12 drive wheels?!?!?! archiver 2001 12 23-06-2002 23:22
