Go to Post What isn't fun about watching a robot hang tubes? I love watching my team do it! - Michael Corsetto [more]
Unread 03-11-2004, 17:14
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
What teams have used belt drive on previous robots?
what teams have used belt drive on thier robots? im thinking of using it for this and this. i once again look forward to your posts!
thanks,
pb
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 03-11-2004, 17:28
MOEmaniac's Avatar
MOEmaniac MOEmaniac is offline
The Crazy One
AKA: Steve
FRC #0365 (MOE)
MOEmaniac has a spectacular aura aboutMOEmaniac has a spectacular aura about
Send a message via AIM to MOEmaniac Send a message via Yahoo to MOEmaniac
Re: What teams have used belt drive on previous robots?
If by belt drive, you mean treads. MOE 365 used treads in 2001 on Lil' MOE
When logic fails, force prevails!
2005 Record
Pittsburgh Regional: #1 seeded, Finalist - Thanks teams 808 and 869, Entrepreneurship Award, Sportsmanship Award, Website Award
Philly Regional: #2 seeded, Champions - Thanks teams 56 and 316, WFA Lou Rosanio, Chairmans Award
Nationals: Still to come
2004 Record
New Jersey Regional: Quarterfinalists - Thanks teams 25 and 103, Judges Award
Philly Regional: Quarterfinalists - Thanks teams 1370 and 1143, Imagery Award, Website Award, WFA Joe Perrito
Nationals: Galileo Finalists - Thanks teams 177 and 27, National Imagery Award
Unread 03-11-2004, 23:08
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
We used timing belts to drive our robot last year (4 wheel drive, 2 motors per side). We had 4 sets of belts on each side between the motors and the wheels, and we discovered that in some places belts work well, while in other places it would be better to use chain.
For example, the belt connecting to the front wheel was the longest and had the most torque being transferred through it, and it tended to either snap or strip itself to uselessness when push came to shove in a match, no matter how much we tensioned them. We ended up switching to #35 chain for just that section. On the other hand, we never had problems with the relatively short belt connecting the two motors together.
To sum up, here are what we found to be the pros and cons of belt drive:
Pros:
- belts are lightweight compared to chains; also, you can get by with aluminum pulleys which tend to be lighter than steel sprockets
- they come in fixed lengths, so no fiddling around with links and half-links
Cons:
- belts tend to strip or snap in high-torque situations
- replacing belts during competitions is time consuming since you can't just join the ends together like with chain (we got around this by looping several spare belts around the shafts and zip-tying them out of the way)
- they have to be really well tensioned so as not to slip/strip (chains are much more forgiving)
- belts tend to slip off their pulleys if not well aligned, unlike chains
I hope this helps you out.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 03-11-2004, 23:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We used two XL series 3/8" wide timing belts to lift our arm for the light weight. We kept them tensioned very well but often times they still slipped. We broke a belt twice. We were able to uncap the small goal with this arm, but that is about the limit before they started slipping. We probably would have been better off going with something like #35 plastic roller chain.
Unread 04-11-2004, 03:42
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Are you referring to Belts as opposed to wheels in a Drive system or belts and chain as part of the drive system
Team 522 also has used belt drive in 3 out of the 4 years of their exsistance and found it to be quite dominating if you use the right belt for the right game for the right surface the robot was running on:
2001 - Their robot used belt drive
Pros: it was superior for pushing a disabled robot to the end zone for pts.
Cons: it appeared they had some issues but not major ones when the robot was run in reverse.
2003 - Their robot used belt drive
Pros: it was superior for traction & as well as being immovable when it came time to be king or in the robots case "QUEEN" of the hill.
Cons: Non really noticeable A job well done by that time.
2004 - Their robot used belt drive
Pros: same as above & it was superior for climbing capability
Cons: same as above
C:\ START RANT HERE
Some teams have their different opinions about belts: belts are good for one thing but have their defects. I would choose belt over chain any day
1) belts won't damage the playing surface but will pop the balls due to friction unlike chains which can either scratch / tear the playing surface and possible pop the balls.
2) Traction - Different belts give you different traction capability unlike chain
3) I personally think that belts are quicker to change then chain
3a) if the robot is designed a certain way the chain may not fit the same way when you first put it on - almost as if it changed its size magically - this statement is just off of speculation and not an actual fact
3b) you have to fiddle with getting the half / master link on
3c) there's the slight off set that you could lose a part critical to keeping the chain in one piece
3d) for belt drive if the robot is designed a certain way the pulley / sprocket systems can be un - bolted and removed so that you just drop the belt ride in place and bolt everything up.
3e) as said before the belt is in one piece already
3f) a part lost on the floor for a belt system can easily be spotted / replaced
Attached at the bottom are some pics i found on delphi of team 522's robots.
Don't build something because you want to; build it because you need to!
meaning don't build a belt / chain / wheeled system because you want to, build it because thats gonna be the main key in helping you win the game aside from the scoring capabilites you want your robot to have.
ID:	2590  Click image for larger version
ID:	2591  Click image for larger version
ID:	2592  Click image for larger version
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 04-11-2004, 11:33
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
Aces high, team 176, used them in 2004. I don't remember how well it worked for them, but i remember at UTC, they had a few problems such as some of them snapping. BUT, they worked good for them at BAE since they ended up winning. You can look a little bit more into their 2004 bot if you want more info, or just talk to someone from their team on the forum.
(if they were not timing belts, then I am sorry for this post, but i am 99% that they were)
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 04-11-2004, 11:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I may be wrong, but I think he's asking how many people used belts to drive their wheels, instead of chain, not belts instead of wheels
2001-2004: Team 100
2006-Present: Team 254
Unread 04-11-2004, 15:02
FRC #1405
thank you very much cory, sorry if i wasn't clear enough.
Unread 04-11-2004, 16:37
Andy Baker Andy Baker is online now
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
(here ya go, Alex)
We (team 45) have used treads to propel the robot, but not belts to drive the wheels. I like the direction you are going, and I have wondered how well a FIRST robot would work by using "v-belts" or powered timing belts to drive the wheels. Heck, motorcycles do it (Harley Davidson, at least).
Just like a tank, treaded drive, you have to watch belt alignment and tension. These are the two important factors with any belt design issue. I assume that the advantage of chain (especially 35 series) is that it can handle misaligned sprockets better than belts can handle misaligned pulleys. Also, chain does not need as much tension to work adequately.
In industry, belts are used all over the place to power SCARA robots, linear actuators, and conveyor equipment.
I believe that it CAN be done on a FIRST robot. A *think* that a belt-drive drive base can be made lighter than a chain & sprocket drive base, as long
as it is done correctly.
Andy B.
Unread 04-11-2004, 17:04
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
i'm pretty sure that in 2003, team 1083 (emoticons) used belt drives. you might wanna try PMing George1083 about it.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 06-11-2004, 09:08
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Timing belts and pulleys are typically advertised as a replacement to chains and sprockets. Chains have a couple major problems: a low lifetime (which FIRST teams generally don't need to worry about), and a tendency to stretch. Companies like Mectrol and Gates make belts that they claim do not stretch, and have an extremely long life.
The downside is that they are a pain in the neck. Unlike chain, you can't simply remove or add a link. So you've got to design your system right the first time. You cannot allow any distance change in between your two (or more) pulleys. If one pulley moves towards the other, for example, your belt is going to strip teeth or skip teeth. Finally, you have to pretension your belt to a known pretension that you can calculated based on the belt geometry. If your pretension is to small, it will cause excessive belt wear or the teeth will skip. If too high, your belt may snap under high loads. It's very hard to come up with a simple way to pretension the belts. There are two ways I've considered when designing a belt transmission. First, you can place spring-loaded idlers in the system, which add the tension you want. It sounds simple, but it makes design complicated. Further, for power transmission applications like FIRST, you need to move in both directions. So you've got to have an idler on both sides of the belt (slack side and powered side). The other option is what I prefer, but still is not simple. You need to set up your system so that when you install the belt, you have a means of increasing the center distance between the two pulleys until the belt is properly tensioned. Then, you need a way to lock the system in that location so that it never moves.
The bottom line is that belts are great for some industrial applications because they can have little to no maintenance. On the other hand, FIRST robots have a very short lifetime and you don't have much time to spend on design... So chains make a lot of sense to me.
Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
One-Regional versus Multi-Regional teams Natchez Regional Competitions 25 20-04-2004 20:40
**FIRST EMAIL**/Important Information for All Championship Teams! Jeremy Roberts FIRST E-Mail Blast Archive 0 09-04-2004 21:12
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
BattleBots IQ BSMFIRST Televised Robotics 37 15-10-2001 01:29
Team Forum Emily Jenkins General Forum 16 14-08-2001 00:37
