Go to Post You don't have to build a robot to be on a robot team. This isn't about the robot, it's about learning. - engunneer [more]
Unread 03-11-2004, 15:43
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Question How do you drive the KOP 6" wheels?
I'm trying to design a 6 wheel drive system and i can't figure out how to drive them. it goes with this thread. i cant seem to figure out how to get it there and capable to drive other then take out the bearing and find a smaller one that fits inside it and has a key way, i look forward once again to your posts!
thanks,
pb
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 03-11-2004, 15:55
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: How do you drive the KOP 6" wheels?
In the past we have used a hub (found on www.firstcadlibrary.com under mechanical) with a sprocket attached to it. You will probably need wheel wedges also (found on www.firstcadlibrary.com under manufactured). Last year we attached a gear to an aluminum adaptor to the hub to drive our tri-wheels. You may want to machine the hub's yourself out of Delron because we found the "MMH" version to be too weak. They broke apart quite eaily because they are molded.
If you need some more 6" wheels for your idea let me know. We have a bunch here. Good luck with your 6 wheel drive, I can't wait to see it run. If you need any help let me know.
Unread 03-11-2004, 15:57
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
delron?
did you mean delrin?
if not id like to know what delron is
and what do the wheel wedges do??
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 03-11-2004, 16:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
It seems to me that the wheel wedges do the same thing as the wheel hub on firstcadlibrary.com but the hub includes an extra 1/4" - 1/2" plate to mount things to.
The wedges (and the cutouts on the hub) fit in the spaces between the "spokes" on the wheel. All it does is make a flat surface to mount the wheel to a base or, a sprocket.
See picture here. This one uses the wheel hub (with the sprocket on the opposite side mounted on the open part of the hub). Open part of the hub meaning the side without the flat surface. In this case, the flat surface sits flush to the spoke and the sprocket is mounted on the opposite side.
http://www.team237.com/gallery/6-Wee...-Time/MVC_048F
Unread 03-11-2004, 16:23
FRC #1405
ok, so basically the wheel is driven by the spokes since it is pushed byt the hub that goes inside the wheel? do i get it right?
and heres the sprocket = http://www.team237.com/gallery/6-Wee...-Time/MVC_056F, http://www.team237.com/gallery/6-Wee...-Time/MVC_024F
Unread 03-11-2004, 16:40
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
On SwampThing we used .5" shaft with the 6" wheels we turned delrin adapters for them and used spring pins. However in finals at UCF a pin sheared and Pretty much crippled it for a match. had it not failed we would have won that match and possibly the regional. The problem was fixed on the fly By James Jones of 180 by drilling a hole through it all and then using the drill bit he drilled it with it to hammer into the hole he made as a codder pin. As for the 6" wheels they are excellent wheels especially after they have been used for a while then they have a flat tread and are in their prime. they aren't very great for traction but that is perfect for 4 wheel drive. we were second seed at UCF and undefeated Winners of the Robot rodeo.
Last edited by Tytus Gerrish : 03-11-2004 at 16:46. Reason: Gosh My spelling sucks
Unread 03-11-2004, 18:10
AKA: Rees
Originally Posted by SpaceOsc
delron?
Yes, sorry for the confusion. I did mean Delrin. Elgin is also right on with the wedges. I was looking at some pictures of our robot from last year and we made our wedges out of aluminum. http://www.team340.com/gallery/robot/113_1374?full=1
We also added a little something to the tread of the wheels to help them stick. We turned the rubber down to a flat surface and put on a little traction. Something we had left over from our 2003 wheels. It worked great. We didn't spend much time on the carpet so turning wasn't an issue. When we did test the traction on the carpet she didn't turn as easy as our past 4 wheel robots.
And PB any time you want to stop by & check out our robot or "supplies" you are more than welcome. You must know how the Rochester teams are always willing to share with each other.
Unread 04-11-2004, 17:14
Originally Posted by Pit Bull 1126
ok, so basically the wheel is driven by the spokes since it is pushed by the hub that goes inside the wheel? do i get it right?
Yup.
Globe gear box Pat Roche Motors 9 25-05-2004 22:50
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Need 6" wheelchair wheels! archiver 2001 5 24-06-2002 03:08
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Rumor or no--- WPI has 12 drive wheels?!?!?! archiver 2001 12 23-06-2002 23:22
