Re: Regional Improvements
I think this is a great thread, except for one thing...what are you going to do about it?
Part of that is what the Team Forums are for - taking suggestions just like these and voicing them to the ones that make decisions about the stuff you're suggesting. Since those have passed for comments on the '04 season, the best thing to do would be to contact your regional planning committee. they'll be the most able to handle the suggestions that are specific to their regional, and I'm sure they would be able to know who to pass your suggestion to for a general event suggestion. So...get to it! ![]() |
Pit Space an organization is definitely a problem at some regionals. I know GLR had far too many teams in too small a space. The aisles and pits were both small, so a team gathering at their pit after a match would mostly block and entire aisle. I don't know what exactly they can do about it, but something should be done.
As for making pits much much bigger where there's space, I think FIRST wants things mostly equitable between regionals, so I don't think they'd allow hug pits at regionals that have space. |
The reason i started this discussion was to get general ideas of what could/should/can be changed and to hear the little things that made some regionals run more or less smoothly than others. Who knows, maybe one of the decisions/complaints could eventually cause a rule change like pit space for example. From what i've heard some regionals are going to add this student panel, so it would be good to know what sort of things are the major and minor problems you can bring to these meetings. One thing i'm going to advocate for this year is lowering the stage at the UTC regional because it is about 4-5 feet above ground level, is hard to see if you want to be in front when your team is up, and the little raisers we were forced to stand on near the stage can only hold so many people at once. |
One thing I really did like this past year was the "Team Viewing Area" where you could go stand right next to the field and watch if your own team was competing. They never allowed this before and it was a good change.
It's nice to hear suggestions and ideas for how to improve an event, but keep in mind the financial restrictions many of these events face. In 2000, the UTC regional was an extravaganza, with brightly colored blue and red stage lights to introduce each alliance, with spinning FIRST logos all over the field and in the crowd, with cameras and monitors all over the place. Unfortunately, things had to be scaled back due to financial limitations, into what are now known as "streamlined regionals", but that discussion has already taken place. To add to Elgin's post, here's another thread detailing regional improvements. Realistically though, the best way to influence an event is to go to the team forums at the end of the competition season, and make your voices known to the people in a position to make those changes. |
I think your best bet would be to try to get in touch with the local regional planning comittee instead, really. |
#7
There is a lot of work to putting on a regional, most of it by volunteers. But the more you put in, the more influence you will have. |
| One-Regional versus Multi-Regional teams | Natchez | Regional Competitions | 25 | 20-04-2004 20:40 |
| Top Score overall from regionals | t0ny127 | Regional Competitions | 33 | 13-04-2004 22:30 |
| UTC Regional (NOT competition results) (Thoughts - Suggestions - Improvements) | Elgin Clock | Regional Competitions | 34 | 23-03-2004 18:31 |
| Regional Team List | Jack | General Forum | 5 | 03-01-2003 12:05 |
