Go to Post The most amazing and inspiring character I've met in FIRST, Wayne [Cokeley] has definately shown me the character of a true leader. - Bharat Nain [more]
Unread 05-11-2004, 12:26
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Any problems using SKINNY 32 pitch gears...
Keep in mind that the stress on the gears and dogs that is most critical is the shock load from reversing. This load will be a combination from driver input and impacts on the robot. If you place the shifter in the high rpm, low torque section than you may have some shearing of the pins during shift on the fly.
Reliability is key, testing will prove your design. I suggest building now and test before the season starts. This will allow you to make changes before you need to build your new gearboxes. In 2003 we built our first dual speed in August and tested during the off-season. Several changes were implemented based on driver feedback for our 2004 design.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 05-11-2004, 17:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What material are they? I would recommend against aluminum or brass at all. Something like stainless or hardened steel will be alright in the applications listed above. I would not recommend doing the actual shifting with these gears. Keep them very near the motors in your drivetrain and they should be okay.
gears Michael Leicht Inventor 12 16-09-2004 10:52
Looking for gears from BostonGear in Inventor.. geo Inventor 6 05-08-2004 10:07
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
Looking for nylon worm gears (~64 pitch) Travis Covington Technical Discussion 3 12-03-2004 22:30
Gear Pressure Angle and Pitch. Patrick Wang Technical Discussion 20 13-08-2002 20:33
