My encoders let me drive straight to you.
Unread 06-11-2004, 08:24
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: sphere bot
my guys have discussed the idea in the past -especially considering the times we got Gyrochips in the kits - but other than roll around we couldn't figure out how it would play the game.
See if you can find the old toy called the Bumble Ball- it may give you some ideas on how to make this thing walk around. There are a number of cat toys that work on similar acentric cams and such.
If you do decide to build one I would certainly love to see how you do it....
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 06-11-2004, 08:57
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: sphere bot
Yeah, the idea is cool, but it would pretty much ruin the mobility of your robot if you were to put out any appendages to actually manipulate something in the game.
Thinking about it though, Stack Attach might have worked with this. If you could get some actual power.
Unread 06-11-2004, 13:11
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Re: sphere bot
that would be aweosme...actually just having a sphere bot would be awesome...if i was going to build one, i'd jsut use 1" square moly tubing and bend it to make a frame, and then just cover that in sheets of aluminium that have been run through an english wheel a abunch of times, or something like 22-gauge sheetmetal....but i have no idea how this would effect the weight issue
Unread 06-11-2004, 16:03
lbridgwater's Avatar
lbridgwater lbridgwater is offline
AKA: Lyndon
FRC #0118 (Robonauts), FRC #696 (Circuit Breakers), FRC #1160(Firebird)
lbridgwater will become famous soon enough
Send a message via AIM to lbridgwater
Re: sphere bot
This is Roboball, it was designed , built and tested within about 6 weeks. most components are FIRST legal though I had to swap out a few things in order to fit under my weight limit of about 20 Kg ( 44 lbs). First ran about this time last year. It is capable of about 20 mph and will run for about an hour before the motors over heat or the battery for the IFI EDU controller dies. The ball material is a 50 inch diameter big-ins ball similar to the ones that have been used in a few FIRST competitions in the past. the little green wheels are just there in case the pendulum arm impacts the ground while traveling over bumpy terrain. It is inflatable and yes can travel across water.
ID:	2598  Click image for larger version
Last edited by lbridgwater : 06-11-2004 at 16:07. Reason: spell recheck and add info
Unread 06-11-2004, 16:12
Programming User
Re: sphere bot
That's awesome!
Question though... is it able to turn? It's hard to tell from the pictures. (Being only two. And I'm an idiot programmer nerd who ignores the peasants who build the robot. )
Unread 06-11-2004, 16:20
AKA: Lyndon
Re: sphere bot
Definately able to turn, the pendulum interal to the deveice is leaned over at any angle you want and it will cause the sphere to lean over as well and as long as it is traveling forward it will turn, much like a motorcycle when you lean. Similarly the ball can lean so far over that it places the metal disks on the sides of the ball onto the ground and literaly turn on a dime. Though its nearly unstable if you try and turn at full speed. Tends to make the ball flip over, always a fun thing to see.
Unread 07-11-2004, 13:00
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
Re: sphere bot
I've always thought about it, never have proposed it to my team, but I've thought about it.
Thinking about it though, Stack Attack might have worked with this. If you could get some actual power.
There is no 'might have' with a sphere bot and Stack Attack. It would have been a champion bot just for the defensive capability and manuverability. I can see it knocking stacks of boxes down by 'bowling' into them and becoming king of the hill by rolling on top another bot or just evading them.
On a side note, why did I instantly think Samus when I saw this thread?
Source: Nintendo.com
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 07-11-2004, 15:51
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: sphere bot
http://downloads.solarbotics.com/PDF/kit6.pdf http://www.chiefdelphi.com/forums/sh...ighlight=robot
Oddly enough this has been talked about before. It just was in the chitchat forum. Of course the robot discussed there pushed the definition of robot to the extreme.
Unread 14-12-2004, 13:07
Adam Y.'s Avatar
Adam Y.
no team (?????)
Re: sphere bot
Please excuse me double posting but I figured it would be better than starting another thread on the same topic. Aparently there is a patent on a spherical robot. It was really quite random on how I discovered it because I was searching for the person's name. If anyone actually recognizes the name then you probably would know why I was curious.
Shperical robot patent
Unread 14-12-2004, 22:06
occra 23.
AKA: ryo
None #1481
Re: sphere bot
i just noticed. if you can have the spherical robot folded at the start and it folds out so the starting height limit is a little below the centerline of the sphere, then as much as other teams push you (assuming other teams robots only push from below the height limit), then they will not be able to push you (well they would, but) if you have a high traction, you can roll right over them no problem. anyone understand what im trying to say? please rephrase this then.
Unread 14-12-2004, 22:41
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: sphere bot
How would you change the size of the sphere? If it were somehow inflateable, it seems too easy to pop. I can't see any other expansion method being robust enough to work consistently.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 01-03-2005, 00:14
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: sphere bot
Looking at lbridgwater's robot it may be possible to place a blower inside that central pole and have the pole open on one end and drill venting holes below where you place the blower, such that when the blower was run it would pull air into the pole and exhaust it out into the robot thru the venting holes. Now all you have to do is figure out how to wire that motor. Not to sure if that could easily be done but thats an idea.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 14-12-2004, 22:48
Levin571's Avatar
Levin571 Levin571 is offline
DC Regional VC
no team (Former Team Paragon member)
Levin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud of
Send a message via AIM to Levin571
Re: sphere bot
Another idea commonly passed around before was the idea of the hoverbot which would be cool to see but i haven't looked in the rule book for a while to see if it would be allowed
2012 FIRST DC Volunteer Coordinator
2003-2005 Driver/Operator
2006 Scout
2004 UTC New Englands Winner
Co-Founder of FF
Unread 14-12-2004, 22:52
phrontist's Avatar
Proto-Engineer
Re: sphere bot
It's perfectly legal, but even if you made it work you'd drain almost all of your resources (weight, power, fabrication time) doing it and in the end have a pretty useless bot.
Oh, btw, I fence foil, and I've challenged Max Lobovsky to a duel if we go to nationals...
Are you strictly saber?
Unread 14-12-2004, 23:09
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Re: sphere bot
If it is a sphere bot, then it is as wide as it is tall....and the width and length starting dimensions are much smaller, so it would have to be folded a lot or inflateable which probably wouldn't be to efficient because it would take a while to inflate anything strong enough to be on a FIRST field.
See you in DC!
worst experience mike pawlak Chit-Chat 15 06-12-2004 07:04
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
Team 1072 (Harker Robotics Team)'s bot: Tork AlbertW Robot Showcase 8 19-02-2003 13:19
what did people think of my teams bot this year (263) Rob Colatutto General Forum 8 22-05-2002 19:03
Multiple Regional Winners and a little jab JamesJones General Forum 32 10-04-2002 23:38
