Re: sphere bot
This is Roboball, it was designed , built and tested within about 6 weeks. most components are FIRST legal though I had to swap out a few things in order to fit under my weight limit of about 20 Kg ( 44 lbs). First ran about this time last year. It is capable of about 20 mph and will run for about an hour before the motors over heat or the battery for the IFI EDU controller dies. The ball material is a 50 inch diameter big-ins ball similar to the ones that have been used in a few FIRST competitions in the past. the little green wheels are just there in case the pendulum arm impacts the ground while traveling over bumpy terrain. It is inflatable and yes can travel across water.
Last edited by lbridgwater : 06-11-2004 at 16:07. Reason: spell recheck and add info |
Re: sphere bot
That's awesome!
![]() Question though... is it able to turn? It's hard to tell from the pictures. (Being only two. And I'm an idiot programmer nerd who ignores the peasants who build the robot. ) |
Re: sphere bot
Definately able to turn, the pendulum interal to the deveice is leaned over at any angle you want and it will cause the sphere to lean over as well and as long as it is traveling forward it will turn, much like a motorcycle when you lean. Similarly the ball can lean so far over that it places the metal disks on the sides of the ball onto the ground and literaly turn on a dime. Though its nearly unstable if you try and turn at full speed. Tends to make the ball flip over, always a fun thing to see.
Re: sphere bot
I've always thought about it, never have proposed it to my team, but I've thought about it.
On a side note, why did I instantly think Samus when I saw this thread? ![]() Source: Nintendo.com |
Re: sphere bot
http://downloads.solarbotics.com/PDF/kit6.pdf http://www.chiefdelphi.com/forums/sh...ighlight=robot
Oddly enough this has been talked about before. It just was in the chitchat forum. Of course the robot discussed there pushed the definition of robot to the extreme. Last edited by Adam Y. : 07-11-2004 at 15:54. |
Re: sphere bot
Please excuse me double posting but I figured it would be better than starting another thread on the same topic. Aparently there is a patent on a spherical robot. It was really quite random on how I discovered it because I was searching for the person's name. If anyone actually recognizes the name then you probably would know why I was curious.
Shperical robot patent |
#7
Re: sphere bot
i just noticed. if you can have the spherical robot folded at the start and it folds out so the starting height limit is a little below the centerline of the sphere, then as much as other teams push you (assuming other teams robots only push from below the height limit), then they will not be able to push you (well they would, but) if you have a high traction, you can roll right over them no problem. anyone understand what im trying to say? please rephrase this then.
#8
Re: sphere bot
Re: sphere bot
Re: sphere bot
Another idea commonly passed around before was the idea of the hoverbot which would be cool to see but i haven't looked in the rule book for a while to see if it would be allowed
#11
Re: sphere bot
Oh, btw, I fence foil, and I've challenged Max Lobovsky to a duel if we go to nationals... Are you strictly saber? |
#12
Re: sphere bot
Re: sphere bot
i was kinda thinking maybe a folding the shpere in eight peices. cutting it into 4 from each "side" of the box. then kinda swinging it in.. if there was a good strong light easy reliable way to do this with say,,, sheet metal, and cover the outside with some treads as to fit in the rules, maybe, but then again that just might not be strong enough. well a honeycomb structure sandwiched between two sheetmetal shperes. tediously welded together or sumthing.. mebe. but theres the lexan and heatgun idea again too. and for propolsion. probably try to have a thing inside the sphere that is independant of the shpere and rolls inside an easy omnishperical robot can be like
................______ ............/....omnis...\ .........../.......[]........\ ..........|........[].........| ...........\.......[]........./ .............\....omnis.../ ................-------- comprehende? my idea is, you need easy access inside the sphere obviously, so why not just have it expand out from an open to a closed more stable structure. |
| worst experience | mike pawlak | Chit-Chat | 15 | 06-12-2004 07:04 |
| Help! My 2003 Bot compressor won't shut off | Jack21 | Control System | 10 | 11-02-2004 12:24 |
| Team 1072 (Harker Robotics Team)'s bot: Tork | AlbertW | Robot Showcase | 8 | 19-02-2003 13:19 |
| what did people think of my teams bot this year (263) | Rob Colatutto | General Forum | 8 | 22-05-2002 19:03 |
| Multiple Regional Winners and a little jab | JamesJones | General Forum | 32 | 10-04-2002 23:38 |
