Go to Post There MUST BE room for mistakes. That’s one of the best ways to learn. - Ken Leung [more]
Unread 07-11-2004, 12:10
Ben.V.293 Ben.V.293 is offline
Ben.V.293 will become famous soon enough
Send a message via AIM to Ben.V.293
building a hand held tachometer
i do alot of work with small engines and i have been looking into buying a non contact tachometer but i cant find any for less than $200. I was wondering if it would be possible to build one useing a light sensor. I'm just uncertain as to how to convert the pulse from the light sensor into numbers on a display. Any help would be greatly apreciated.
Thanks,
Ben Van Selous
Unread 07-11-2004, 18:00
Re: building a hand held tachometer
Ben,
There are number of circuits out there if you search for them. It is possible to use a light sensor with a light source. Once you get that far you need to filter the signal to cancel out the noise and then send that to a counter. Add to that a semi accurate time base and all you need to do is to interface your results to a display of some sort. When you add up all that is needed, one of those tachometers in McMaster Carr looks pretty nice.
Unread 07-11-2004, 18:28
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Have you checked out the ones Harbor Freight has for $70? I have seen them on sale for $60 at times.
Photo Sensor:
http://www.harborfreight.com/cpi/cta...emnumber=41727
Digital Touch:
http://www.harborfreight.com/cpi/cta...emnumber=41726
Unread 07-11-2004, 18:48
Thanks for your help. mayby i will just buy one. I was just wondering if building one was a possibility.
Thanks,
Ben Van Selous
Best frame building material superbeano2004 Technical Discussion 59 29-04-2005 08:43
Tachometer ZACH P. Motors 11 08-11-2004 04:02
building a robot transport bskll General Forum 22 25-10-2004 19:46
Notes on building the Square Rack archiver 2000 1 24-06-2002 00:06
What purpose are you building your robot for? Anton Abaya General Forum 15 24-01-2002 00:36
